MastroLube Posted October 27, 2016 Share Posted October 27, 2016 Hello! A tittle question... Is it possible to make a ssget with XDATA values? (ssget "_A" '((0 . "TEXT") (8 . "CB_Richiami") (-3 ("_XDATA" (1000 . "196") (1000 . "196"))) )) That code returns always nil ( Maybe the only solution is the selection set processing.. Thanks for your help! Dennis Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 27, 2016 Share Posted October 27, 2016 Unfortunately you can only filter to the level of the application name (see here); you will therefore need to perform the additional filtering by testing each entity when processing the selection set. Quote Link to comment Share on other sites More sharing options...
MastroLube Posted October 27, 2016 Author Share Posted October 27, 2016 Thanks for the reply Mr. Lee! Yeah, as i thought I need to process that list.. (defun mod_elementi (/) (IF (setq s (ssget "_A" '((0 . "TEXT") (8 . "CB_Richiami")))) (progn (setq i 0 n (sslength s) ) (while (< i n) (progn (IF (/= (substr (cdr (assoc 1 (entget (ssname s i)))) 1 2) "1%") (progn (setq x (car s)) (vl-remove x (cdr s)) (setq n (1- n)) ) ) (setq i (1+ i)) ) ) ) ) ) (setq x (car s)) this requires a list.. I need to convert the selection set to a list before.. anyway it's the right way? Thanks! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted October 27, 2016 Share Posted October 27, 2016 What are you trying to modify Dennis? Quote Link to comment Share on other sites More sharing options...
MastroLube Posted October 27, 2016 Author Share Posted October 27, 2016 (edited) This is a little part of a more complex bug fix of a program I use. I've done the fix in another way but it's very inefficient so I started to rewrite the lisp. This is the old code: (DEFUN c:test (/) (IF (SETQ s (SSGET '((0 . "TEXT") (8 . "CB_Richiami")))) (PROGN (SETQ i 0 n (SSLENGTH s) ) (WHILE (< i n) (IF (= (SUBSTR (CDR (ASSOC 1 (ENTGET (SSNAME s i)))) 1 2) "1%") (PROGN (SETQ e (SSNAME s i) testo_originale (SUBSTR (CDR (ASSOC 1 (ENTGET (SSNAME s i)))) 2 20 ) x_data (CDR (CADR (CAR (CDR (ASSOC -3 (ENTGET e '("*"))))))) ) (conta_barre x_data) ;;; (SETQ vobject (VLAX-ENAME->VLA-OBJECT e)) ;;; (SETQ text (VLA-GET-TEXTSTRING vobject)) ;;; (VLA-PUT-TEXTSTRING vobject "New text string") (setq testo_modificato (strcat (itoa n_ferri) testo_originale )) (entmod (SUBST (CONS 1 testo_modificato) (ASSOC 1 (entget e)) (entget e))) ) ) (SETQ i (1+ i)) ) ) ) ) (defun conta_barre (x / i n freccie x_data x e) (if (setq freccie (ssget "_A" '((0 . "INSERT") (8 . "CB_Richiami")))) (progn (setq i 0 n_ferri -1 n (sslength freccie) ) (while (< i n) (setq e (ssname freccie i) x_data (cdr (cadr (car (cdr (assoc -3 (entget e '("*"))))))) i (1+ i) ) (IF (= x_data x) (setq n_ferri (1+ n_ferri)) ) ) ) ) ) It's related to another post you've answered... http://www.cadtutor.net/forum/showthread.php?97959-Find-where-are-stored-information-about-an-entity/page4 Instead of create the quote (wasn't able to identify the number of the bar) I want only to correct in a brutal way the number in front of the text. I've discovered that ARROWS have the same XDATA of the text I want to modify. The idea for the new code is to: 1. get a selection set of all these arrows 2. using your code (THANKS!) to create a list with (XDATA . N°_ITEMS) 3. search TEXT with 1st, 2nd, etc, element of xdata from your code 4. entmod it with the correct number This is what I've write until now: (defun C:test (/) (if (setq s (ssget '((0 . "INSERT") (8 . "CB_Richiami") (2 . "aca_freccia")))) (progn (setq i 0 n (sslength s) lista nil ) (while (< i n) (progn (setq e (ssname s i) x (cdr (cadr (car (cdr (assoc -3 (entget e '("*"))))))) i (1+ i) ) (setq lista (append (list x) lista)) ;;; (setq testo_modificato (strcat (itoa n_ferri) testo_originale )) ;;; (entmod (SUBST (CONS 1 testo_modificato) (ASSOC 1 (entget e)) (entget e))) ) );end while (setq lst (LM:CountItems lista)) ) ) (mod_elementi) ) (defun LM:CountItems ( l / c x ) (if (setq x (car l)) (progn (setq c (length l) l (vl-remove x (cdr l)) ) (cons (cons x (- c (length l))) (LM:CountItems l)) ) ) ) (defun mod_elementi (/) (IF (setq s (ssget "_A" '((0 . "TEXT") (8 . "CB_Richiami")))) (progn (setq i 0 n (sslength s) ) (while (< i n) (progn (IF (/= (substr (cdr (assoc 1 (entget (ssname s i)))) 1 2) "1%") (progn (setq x (car s)) (vl-remove x (cdr s)) (setq n (1- n)) ) ) (setq i (1+ i)) ) ) ) ) ) I'm stacked with the point 3.. Anyway the point 4 (entmod) create some problems.. a lot of items generated with the program I use get messed. I don't know why.. If I ssget little portions of drawing that doesn't happen. FIXED Edited October 28, 2016 by MastroLube Find an error in the old code Quote Link to comment Share on other sites More sharing options...
