JerryC Posted November 15, 2016 Share Posted November 15, 2016 I draw a .25 circle on a part that will be cut as a hole on a laser. When the laser cuts the hole its an 8 sided hole. How can I change it to be round? Autocad 2016. I have tried setting the options to 20000 and 360. Nothing phases a change in the output. Regen dont help except appearing round in the autocad drawing. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 16, 2016 Share Posted November 16, 2016 What type of file are you supplying to the laser? Can you post a drawing with the circle in question (don't need the entire drawing, just the circle)? AFAIK, all such devices cut a series of small straight lines for arcs and circles. There have been a few discussions on CADTutor about how that works. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted November 17, 2016 Share Posted November 17, 2016 2nd SLW210, sounds like your laser software has a overiding setting. At times you will see facets for a circel this is a programming video technique that a series of lines is faster to display than a true circle. BUT as far as Autocad is concerned the geometry is a centre point with radius. Quote Link to comment Share on other sites More sharing options...
