any help for a lisp to convert a selection set of lines to 3dpolylines
thanks for any kind of help
(defun c:l3dpl ( / UNIQUE CHOICE1 CHOICE2 ENENT ENPT ENPTT ENT K NXTENTEN NXTENTST OSM PTLST SEPT SEPTN SEPTS SS SSS STENT STPT )
 (defun unique ( L FUZZ )
   (if l (cons (car l) (vl-remove-if '(lambda ( x ) (equal x (car l) fuzz)) (unique (cdr l)))))
 (vl-cmdf "_.UCS" "w")
 (setq osm (getvar 'osmode))
 (setvar 'osmode 0)
 (prompt "\nSelect all connected lines")
 (setq ss (ssget '((0 . "LINE")) ))
 (setq sss (ssadd))
 (repeat (setq k (sslength ss))
   (setq ent (ssname ss (setq k (1- k))))
   (ssadd ent sss)
   (setq stpt (cdr (assoc 10 (entget ent))))
   (setq enpt (cdr (assoc 11 (entget ent))))
   (setq septs (cons stpt septs))
   (setq septs (cons enpt septs))
 (setq sept septs)
 (defun chkduppt (pt lst / chk)
   (foreach ptt lst
     (if (equal pt ptt 1e-6) (setq chk (cons T chk)))
   chk
 (foreach pt septs
   (if (eq (length (chkduppt pt septs)) 2) (setq septn (cons pt septn)))
 (foreach pt septn
   (setq sept (vl-remove pt sept))
 (if (eq sept nil) (setq sept (unique septs 1e-6)))
   (if (equal stpt (car sept) 1e-6) (setq stent ent))
 (if (eq stent nil)
     (if (equal enpt (car sept) 1e-6) (setq enent ent))
 (if stent
   (setq ptlst (cons (cdr (assoc 10 (entget stent))) ptlst))
   (setq ptlst (cons (cdr (assoc 11 (entget stent))) ptlst))
   (setq enpt (cdr (assoc 11 (entget stent))))
   (ssdel stent ss)
   (setq ptlst (cons (cdr (assoc 11 (entget enent))) ptlst))
   (setq ptlst (cons (cdr (assoc 10 (entget enent))) ptlst))
   (setq enpt (cdr (assoc 10 (entget enent))))
   (ssdel enent ss)
 (while (/= (sslength ss) 0)
   (setq nxtentst nil)
   (setq nxtenten nil)
     (if (equal enpt stpt 1e-6) (setq nxtentst ent))
   (if nxtentst nil
       (setq enptt (cdr (assoc 11 (entget ent))))
       (if (equal enpt enptt 1e-6) (setq nxtenten ent))
   (if nxtentst
     (setq ptlst (cons (cdr (assoc 10 (entget nxtentst))) ptlst))
     (setq ptlst (cons (cdr (assoc 11 (entget nxtentst))) ptlst))
     (setq enpt (cdr (assoc 11 (entget nxtentst))))
     (ssdel nxtentst ss)
     (setq ptlst (cons (cdr (assoc 11 (entget nxtenten))) ptlst))
     (setq ptlst (cons (cdr (assoc 10 (entget nxtenten))) ptlst))
     (setq enpt (cdr (assoc 10 (entget nxtenten))))
     (ssdel nxtenten ss)
 (setq ptlst (unique ptlst 1e-6))
 (initget 1 "Open Close")
 (setq choice1 (getkword "\nIs 3dpolyline opened or closed (Open/Close) : "))
 (if (eq choice1 "Open")
   (command "_.3dpoly")
   (foreach pt ptlst
     (command pt)
   (command "")
   (foreach pt ptlst
     (command pt)
   (command "c")
 (initget 1 "Keep Delete")
 (setq choice2 (getkword "\nDo you want to keep lines, or do you want me to delete them (Keep/Delete) : "))
 (if (eq choice2 "Delete")
   (command "erase" sss "")
 (vl-cmdf "_.UCS" "p")
 (setvar 'osmode osm)
HTH. M.R.
thank you marko for you reply
i tried your lisp the lines still lines not converted to 3d polylines
one more think the lines set have z elevation and these line not necessary contected
If the lines are not connected this opens a can of worms what rules apply to connect them ? If the ends are close and have different Z's which do you use when joining ?
  • 2 weeks later...
Better ever, than never...
(defun c:joinlines23dpolys ( / *error* _vl-position uniquechain adoc ss ti elst el1 el2 el3 ee e eg egg entl pl p pp f chainl vertl vts tmp )
 (vl-load-com)
 (defun *error* ( m )
   (vla-endundomark adoc)
   (if m
     (prompt m)
 ;; (_vl-position 3.29 '(1.1 2.2 3.3 4.4 5.5 6.6 7.7 8.8 9.9) 0.01 nil) => 2 (!k => nil) ;;
 (defun _vl-position ( e l tol k )
   (if (null k)
     (setq k 0)
   (if (not (equal e (car l) tol))
       (setq k (1+ k))
       (if (cdr l)
         (_vl-position e (cdr l) tol k)
         (setq k nil)
     k
 (defun uniquechain ( l )
   (if l (cons (car l) (uniquechain (vl-remove-if '(lambda ( x ) (or (and (equal (caar l) (car x) 1e-6) (equal (cadar l) (cadr x) 1e-6)) (and (equal (caar l) (cadr x) 1e-6) (equal (cadar l) (car x) 1e-6)))) l))))
 (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object))))
 (setq ss (ssget "_:L" '((0 . "LINE"))))
 (setq ti (car (_vl-times)))
 (setq elst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
 (setq entl (mapcar '(lambda ( x ) (list (vlax-curve-getstartpoint x) (vlax-curve-getendpoint x) x)) elst))
 (setq entl (uniquechain entl))
 (foreach e elst
   (entdel e)
 (setq elst (mapcar 'caddr entl))
 (foreach e elst
   (entdel e)
 (foreach e elst
   (cond
     ( (and
         (not
           (vl-some '(lambda ( x )
             (or
               (equal (vlax-curve-getstartpoint e) (vlax-curve-getstartpoint x) 1e-6)
               (equal (vlax-curve-getstartpoint e) (vlax-curve-getendpoint x) 1e-6)
             )) (setq tmp (vl-remove e elst))
         (not
             (or
               (equal (vlax-curve-getendpoint e) (vlax-curve-getstartpoint x) 1e-6)
               (equal (vlax-curve-getendpoint e) (vlax-curve-getendpoint x) 1e-6)
             )) tmp
       (setq el1 (cons e el1))
     ( (and
           (or
           )) tmp
           (or
           )) tmp
       (setq el3 (cons e el3))
     ( t
       (or
         (and
             (or
           ) tmp)
           (not
               (or
             ) tmp)
         (and
           (not
               (or
             ) tmp)
             (or
           ) tmp)
       (setq el2 (cons e el2))
 (setq elst (append el1 el2 el3))
 (while (or ee (setq e (car elst)))
   (if (vl-some '(lambda ( x )
     (or
     (cond
       ( (vl-some '(lambda ( x ) (if (equal (vlax-curve-getstartpoint e) (vlax-curve-getstartpoint x) 1e-6) (setq ee x) (setq ee nil))) tmp)
         (if (not (vl-position e eg))
           (setq eg (cons e eg))
       ( (vl-some '(lambda ( x ) (if (equal (vlax-curve-getstartpoint e) (vlax-curve-getendpoint x) 1e-6) (setq ee x) (setq ee nil))) tmp)
       ( (vl-some '(lambda ( x ) (if (equal (vlax-curve-getendpoint e) (vlax-curve-getstartpoint x) 1e-6) (setq ee x) (setq ee nil))) tmp)
       ( (vl-some '(lambda ( x ) (if (equal (vlax-curve-getendpoint e) (vlax-curve-getendpoint x) 1e-6) (setq ee x) (setq ee nil))) tmp)
     (if (null eg)
       (setq eg (cons e eg) egg (cons eg egg) ee nil eg nil)
         (setq ee nil egg (cons eg egg) eg nil)
   (setq elst (vl-remove e elst))
   (if ee
     (setq e ee)
 (foreach eg egg
   (if (/= (length eg) 1)
     (while (> (length eg) 1)
       (setq pp nil f nil)
       (setq entl (mapcar '(lambda ( x ) (list (vlax-curve-getstartpoint x) (vlax-curve-getendpoint x) x)) eg))
       (setq pl (vl-remove-if '(lambda ( x ) (= (type x) 'ENAME)) (apply 'append entl)))
       (while (setq p (car pl))
         (if (_vl-position p (cdr pl) 1e-6 nil)
           (setq pl (vl-remove-if '(lambda ( x ) (equal p x 1e-6)) pl))
           (setq pp p pl (cdr pl))
       (if pp
         (setq e (vl-some '(lambda ( x ) (if (or (equal (car x) pp 1e-6) (equal (cadr x) pp 1e-6)) x)) entl))
         (setq e (car entl))
       (while e
         (setq chainl (cons e chainl))
           (cond
             ( (and pp (= (length chainl) 1))
               (if (equal (car e) pp 1e-6)
                 (cond
                   ( (equal (cadr e) (car x) 1e-6)
                     (setq f t)
                     x
                   ( (equal (cadr e) (cadr x) 1e-6)
                     (setq f nil)
                     x
                 (cond
                   ( (equal (car e) (car x) 1e-6)
                     (setq f t)
                     x
                   ( (equal (car e) (cadr x) 1e-6)
                     (setq f nil)
                     x
             ( (= (length chainl) 1)
               (cond
                   (setq f t)
                   x
                   (setq f nil)
                   x
             ( t
               (cond
                 ( (and f (equal (cadr e) (car x) 1e-6))
                   (setq f t)
                   x
                 ( (and f (equal (cadr e) (cadr x) 1e-6))
                   (setq f nil)
                   x
                 ( (and (null f) (equal (car e) (car x) 1e-6))
                   (setq f t)
                   x
                 ( (and (null f) (equal (car e) (cadr x) 1e-6))
                   (setq f nil)
                   x
           ) (setq entl (vl-remove e entl))
       (setq chainl (reverse chainl))
       (if pp
         (setq vertl (append (list (if (equal (caar chainl) pp 1e-6) (caar chainl) (cadar chainl))) (setq vts (mapcar '(lambda ( a b ) (cond ( (equal (car a) (car b) 1e-6) (car a) ) ( (equal (car a) (cadr b) 1e-6) (car a) ) ( (equal (cadr a) (car b) 1e-6) (cadr a) ) ( (equal (cadr a) (cadr b) 1e-6) (cadr a) ) )) chainl (cdr chainl))) (vl-remove-if '(lambda ( x ) (equal x (last vts) 1e-6)) (vl-remove-if '(lambda ( x ) (= (type x) 'ENAME)) (last chainl)))))
         (setq vertl (append (list (caar chainl)) (mapcar '(lambda ( a b ) (cond ( (equal (car a) (car b) 1e-6) (car a) ) ( (equal (car a) (cadr b) 1e-6) (car a) ) ( (equal (cadr a) (car b) 1e-6) (cadr a) ) ( (equal (cadr a) (cadr b) 1e-6) (cadr a) ) )) chainl (cdr chainl))))
       (foreach chain chainl
         (setq eg (vl-remove (caddr chain) eg))
         (entdel (caddr chain))
       (setq chainl nil)
       (if (car vertl)
           (entmake
             (list
               '(0 . "POLYLINE")
               '(100 . "AcDbEntity")
               '(100 . "AcDb3dPolyline")
               '(66 . 1)
               '(10 0.0 0.0 0.0)
               (if pp
                 (cons 70
                 (cons 70 9)
               '(210 0.0 0.0 1.0)
           (foreach pt vertl
             (entmake
               (list
                 '(0 . "VERTEX")
                 '(100 . "AcDbVertex")
                 '(100 . "AcDb3dPolylineVertex")
                 (cons 10 pt)
                 '(70 . 32)
           (entmake
             (list
               '(0 . "SEQEND")
       (setq vertl nil)
 (prompt "\nElapsed time : ") (princ (rtos (/ (- (car (_vl-times)) ti) 1000.0) 2 20)) (prompt " seconds...")
 (*error* nil)
HTH. M.R.
Edited by marko_ribar
code changed - works slower but reliable results...
Here is faster version - without prior sorting of lines... Should be also 100% reliable...
(defun c:joinlines23dpolys ( / *error* _vl-position uniquechain adoc ss ti elst e e1 ee eg egg entl pl p pp f chainl vertl vts tmp )
 (vl-load-com)
   (if m
     (prompt m)
   (if (null k)
     (setq k 0)
       (setq k (1+ k))
       (if (cdr l)
         (setq k nil)
     k
 (foreach e elst
   (entdel e)
 (foreach e elst
   (entdel e)
 (while (or ee (setq e (car elst) e1 e))
     (or
     (cond
     (if (null eg)
       (setq eg (cons e eg) egg (cons eg egg) ee nil eg nil f nil)
       (if (null f)
           (setq ee e1 f t)
           (setq ee nil egg (cons eg egg) eg nil f nil)
   (if ee
     (setq e ee)
 (foreach eg egg
       (setq pp nil f nil)
       (if pp
         (setq e (car entl))
       (while e
           (cond
                 (cond
                     (setq f t)
                     x
                     (setq f nil)
                     x
                 (cond
                     (setq f t)
                     x
                     (setq f nil)
                     x
               (cond
                   (setq f t)
                   x
                   (setq f nil)
                   x
             ( t
               (cond
                   (setq f t)
                   x
                   (setq f nil)
                   x
                   (setq f t)
                   x
                   (setq f nil)
                   x
       (if pp
       (setq chainl nil)
       (if (car vertl)
           (entmake
             (list
               '(0 . "POLYLINE")
               '(66 . 1)
               '(10 0.0 0.0 0.0)
               (if pp
                 (cons 70
                 (cons 70 9)
               '(210 0.0 0.0 1.0)
           (foreach pt vertl
             (entmake
               (list
                 '(0 . "VERTEX")
                 (cons 10 pt)
                 '(70 . 32)
           (entmake
             (list
               '(0 . "SEQEND")
       (setq vertl nil)
 (*error* nil)
HTH., M.R.
