xpr0 Posted November 21, 2016 Share Posted November 21, 2016 how to change the unit of scale in texture editor. Drawing units is in mm. plz help. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted November 21, 2016 Share Posted November 21, 2016 This is just a guess, I have never used the Texture Editor, didn't even know there was such a thing. Try running the MEASUREMENT command at the commandline, and the current measurement units will be displayed, either by a response of (inches), or (metric). If you look at the screenshot from SYSVDLG you will see what that system variable setting controls. It just occurred to me, that this setting might also affect the settings you are asking about. Quote Link to comment Share on other sites More sharing options...
xpr0 Posted November 21, 2016 Author Share Posted November 21, 2016 This is just a guess, I have never used the Texture Editor, didn't even know there was such a thing. Try running the MEASUREMENT command at the commandline, and the current measurement units will be displayed, either by a response of (inches), or (metric). If you look at the screenshot from SYSVDLG you will see what that system variable setting controls. It just occurred to me, that this setting might also affect the settings you are asking about. i checked it. its set to metric . Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 21, 2016 Share Posted November 21, 2016 Maybe contact Autodesk, I have seen tutorials showing them in MM, so I know it can be done. I believe 2015 was the first with the Texture Editor, Dadgad. Quote Link to comment Share on other sites More sharing options...
