Hello everybody!
I'm trying to make DSL dialogue for a small program.
DCL:
perfsuff: dialog {
                       label = "PF";
         : boxed_column
         {             label = "--< Add >--";
         : edit_box
                       label = "Type prefix:";
                       key = "pre";
                       value = "";
                       edit_width = 10;}
         : edit_box
                       label = "Type suffix:";
                       key = "suf";
                       value = "";
                       edit_width = 10;}
         : spacer
         {height = 0.5;}}
         ok_cancel;
Lisp:
(defun c:perfsuff (/ prefiks-txt sufiks-txt spisok znach i)
(initget 1)
(setq prefiks-txt (getstring T "prefix: "))
(initget 1)
(setq sufiks-txt (getstring T "suffix: "))
(setq spisok (ssget '((0 . "*text"))))
(setq i 0)
(while (< i (sslength spisok))
(setq znach (entget (ssname spisok i)))
(setq soderzhimoe (cons 1 (strcat prefiks-txt (cdr (assoc 1 znach)) sufiks-txt)))
(setq znach (subst soderzhimoe (assoc 1 znach) znach))
(entmod znach)
(setq i (1+ i))
(c:perfsuff)
I get something like this:
(if (< (setq num (load_dialog "perfsuff")) 0) (exit))
(if (not (new_dialog "perfsuff" num)) (exit))
(action_tile "pre" "(setq rad1 (atof $value))")
(terpri)
(princ prefiks-txt)
(action_tile "suf" "(setq rad1 (atof $value))")
(terpri)
(princ sufiks-txt)
(terpri)
(start_dialog)
(unload_dialog num)
(setq i 0)
(entmod znach)
(setq i (1+ i))
(c:perfsuff)
But the program does not work, please tell me where the mistake?
A few problems
both pre & suf set the value rad1
prefiks-txt is a nil value in last post
Have a look at this its a multi line dcl have as many lines as you like the example is for 2 lines in code it returns variables Key1 key2 as strings etc
; multi line dcl
; sample code a 2 line example
; By Alan H
; use these two next lines in your code all thats required.
; (if (not AH:getkeys)(load "getvals2"))
;(AH:getkeys (list "Enter prefix " 5 4 "Enter suffix " 5 4 ))
; returns key1 key2 etc
(princ "Getvals2 loaded")
(defun AH:getkeys (INFO / fo fname newlst num x y klist)
; you can hard code a directory if you like for dcl file
;(setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w"))
(setq fo (open (setq fname "c:\\acadtemp\\getkeys.dcl") "w"))
(write-line "ddgetkey : dialog {" fo)
(write-line " : column {" fo)
(setq num (/ (length info) 3))
(setq x 1)
(repeat num
(setq klist (cons (strcat "key" (rtos x 2 0)) klist))
(setq x (+ 1 x))
(setq x 1)
(setq y 1)
(repeat num
(write-line ": edit_box {" fo)
(write-line (strcat "    key = "  (chr 34) (strcat "key" (rtos y 2 0)) (chr 34) ";") fo)
(write-line (strcat " label = "  (chr 34) (nth (- x 1) info) (chr 34) ";"  )   fo)
(write-line (strcat "     edit_width = " (rtos (nth x info) 2 0) ";" ) fo)
(write-line (strcat "     edit_limit = " (rtos (nth (+ x 1) info) 2 0) ";" ) fo)
(write-line "   is_enabled = true;" fo)
(write-line "  }" fo)
(write-line "spacer_1 ;" fo)
(setq x (+ x 3))
(setq y (+ y 1))
(write-line "ok_only;}" fo)
(close fo)
(setq x 1)
(setq outlst '())
(setq dcl_id (load_dialog  fname))
(if (not (new_dialog "ddgetkey" dcl_id))
(exit))
(foreach k klist
     (action_tile k (strcat "(setq " k " (get_tile \"" k "\"))"))
 (action_tile "accept" "(done_dialog 1)")
 (action_tile "cancel" "(done_dialog 0)")
 (setq action (start_dialog))
 (unload_dialog dcl_id)
) ; defun
I'm also interested about dcl-lisp wiring-up, but I'm stuck at obtaining the values from the edit_box(es):
(defun C:test ( / LstDCL FpathWithFname fileDCL dcl_id dlgRtn Prefix$ Suffix$)
(setq LstDCL
	(list
		"PrefSuff : dialog"
		"label = \"PF\";"
		": boxed_column"
		"label = \"--< Add >--\";"
		": edit_box"
		"label = \"Type prefix:\";"
		"key = \"pre\";"
		"edit_width = 10;"
		": edit_box"
		"label = \"Type suffix:\";"
		"key = \"suf\";"
		"edit_width = 10;"
		": spacer"
		"{height = 0.5;}"
		"ok_cancel;"
	); list
); setq LstDCL
(setq FpathWithFname (vl-filename-mktemp nil nil ".dcl")); studied from LM
(setq fileDCL (open FpathWithFname "w"))
(foreach x LstDCL (write-line x fileDCL))
(close fileDCL)
; Load Dialog
(setq dcl_id (load_dialog FpathWithFname))
(and (not (new_dialog "PrefSuff" dcl_id))(exit))
[color="red"]; UNCLEAR what to do below:
; Set Dialog Initial Settings
(set_tile "pre" Prefix$)
(set_tile "suf" Suffix$)
; Dialog Actions
(action_tile "pre" "(setq Prefix$ $value)")
(action_tile "suf" "(setq Suffix$ $value)")
(if (setq dlgRtn (start_dialog))
		(cond
			((= 1 dlgRtn) ; ok was pressed
				(alert (vl-princ-to-string Prefix$))
				(alert (vl-princ-to-string Suffix$))
				(done_dialog)
			((= 0 dlgRtn) ; cancel was pressed
				(done_dialog)
		; Unload Dialog
		(vl-file-delete FpathWithFname)
	); progn
); if[/color]
);| defun |; (vl-load-com) (princ)
Not sure what exactly to do in the red part of the code, any help?
Consider the following example:
[color=GREEN];; Prefix/Suffix Text  -  Example by Lee Mac 2016-11-26[/color]
([color=BLUE]defun[/color] c:ps ( [color=BLUE]/[/color] *error* dch dcl des enx idx pre sel str suf )
   ([color=BLUE]defun[/color] *error* ( msg )
       ([color=BLUE]if[/color] ([color=BLUE]<[/color] 0 dch) ([color=BLUE]unload_dialog[/color] dch))
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'file ([color=BLUE]type[/color] des)) ([color=BLUE]close[/color] des))
       ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 'str ([color=BLUE]type[/color] dcl)) ([color=BLUE]setq[/color] dcl ([color=BLUE]findfile[/color] dcl))) ([color=BLUE]vl-file-delete[/color] dcl))
       ([color=BLUE]if[/color] ([color=BLUE]and[/color] msg ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg [color=BLUE]t[/color]) [color=MAROON]"*break,*cancel*,*exit*"[/color])))
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg))
       ([color=BLUE]princ[/color])
   ([color=BLUE]cond[/color]
       (   ([color=BLUE]null[/color] ([color=BLUE]setq[/color] sel ([color=BLUE]ssget[/color] [color=MAROON]"_:L"[/color] '((0 . [color=MAROON]"TEXT,MTEXT"[/color]))))))
       (   ([color=BLUE]not[/color]
                   ([color=BLUE]setq[/color] dcl ([color=BLUE]vl-filename-mktemp[/color] [color=BLUE]nil[/color] [color=BLUE]nil[/color] [color=MAROON]".dcl"[/color]))
                   ([color=BLUE]setq[/color] des ([color=BLUE]open[/color] dcl [color=MAROON]"w"[/color]))
                   ([color=BLUE]foreach[/color] str
                           [color=MAROON]"ps : dialog"[/color]
                           [color=MAROON]"{"[/color]
                           [color=MAROON]"    spacer;"[/color]
                           [color=MAROON]"    label = \"Prefix/Suffix\";"[/color]
                           [color=MAROON]"    : edit_box"[/color]
                           [color=MAROON]"    {"[/color]
                           [color=MAROON]"        label = \"Prefix:\";"[/color]
                           [color=MAROON]"        key = \"pre\";"[/color]
                           [color=MAROON]"        edit_width = 12;"[/color]
                           [color=MAROON]"    }"[/color]
                           [color=MAROON]"        label = \"Suffix:\";"[/color]
                           [color=MAROON]"        key = \"suf\";"[/color]
                           [color=MAROON]"    ok_cancel;"[/color]
                           [color=MAROON]"}"[/color]
                       ([color=BLUE]write-line[/color] str des)
                   ([color=BLUE]not[/color] ([color=BLUE]setq[/color] des ([color=BLUE]close[/color] des)))
                   ([color=BLUE]<[/color] 0 ([color=BLUE]setq[/color] dch ([color=BLUE]load_dialog[/color] dcl)))
                   ([color=BLUE]new_dialog[/color] [color=MAROON]"ps"[/color] dch)
           ([color=BLUE]princ[/color] [color=MAROON]"\nUnable to write & load DCL file."[/color])
       (   ([color=BLUE]progn[/color]
               ([color=BLUE]setq[/color] pre [color=MAROON]""[/color] suf [color=MAROON]""[/color])
               ([color=BLUE]action_tile[/color] [color=MAROON]"pre"[/color] [color=MAROON]"(setq pre $value)"[/color])
               ([color=BLUE]action_tile[/color] [color=MAROON]"suf"[/color] [color=MAROON]"(setq suf $value)"[/color])
               ([color=BLUE]=[/color] 1 ([color=BLUE]start_dialog[/color]))
           ([color=BLUE]repeat[/color] ([color=BLUE]setq[/color] idx ([color=BLUE]sslength[/color] sel))
               ([color=BLUE]setq[/color] enx ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] sel ([color=BLUE]setq[/color] idx ([color=BLUE]1-[/color] idx))))
                     str ([color=BLUE]assoc[/color] 1 enx)
               ([color=BLUE]entmod[/color] ([color=BLUE]subst[/color] ([color=BLUE]cons[/color] 1 ([color=BLUE]strcat[/color] pre ([color=BLUE]cdr[/color] str) suf)) str enx))
       (   ([color=BLUE]princ[/color] [color=MAROON]"\n*Cancel*"[/color]))
   (*error* [color=BLUE]nil[/color])
You make it look so easy, I don't know what else to say.
Compliments :notworthy:
Thank you.
