Hi all, ive been trying to create simple lisp that do the following
1. Select objects (lines, polylines, circle, arc etc.)
2. prompt the user to put desired linetype scale
but unfortunately my code is not working the way i wanted, any help is highly appreciated. Thank you.
(defun c:TEST (/ SSET )
(setq sset (ssget))
(command "_.CHANGE" SSET "_P" "LTSCALE" ))
(defun C:test ( / n SS i e enx )
(and
	vlax-get-acad-object
	(not (initget (+ 2 4)))
	(or (setq n (getreal "\nSpecify new LTSCALE value < 1 >: ")) (setq n 1))
	(setq SS (ssget "_:L"))
	(repeat (setq i (sslength SS))
		(setq e (ssname SS (setq i (1- i))))
		(vla-put-LinetypeScale (vlax-ename->vla-object e) n)
	); repeat
); and
) (vl-load-com) (princ)
(and
	); repeat
); and
thank you very much Grrr. Cheers!
I also tried with Vanilla:
(and
		(setq enx (entget e))
		(cond
			( (assoc 48 enx)
				(setq enx (subst (cons 48 n) (assoc 48 enx) enx))
			( (not (assoc 48 enx))
				(setq enx (append (list (cons 48 n)) enx))
		); cond
		(entmod enx) (entupd (cdr (assoc -1 enx)))
	); repeat
); and
Seems to work now, it failed the first time so I gave up and used VLISP ( forgot to remove the enx variable from the first code ).
Still doesn't work.
EDIT: oh, and I just had to use
(not (initget 4))
instead of
Edited by Grrr
