MURAl_KMD Posted December 6, 2016 Share Posted December 6, 2016 Which autocad variable controls the display of dialog box display when we use below autolisp codes (note: for most commands which displays dialogs box used at command prompt) (command "._layer" ......) (command "._rename" ......) & so on Thank you in advance Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 6, 2016 Share Posted December 6, 2016 The variable is CMDECHO, as shown in the screenshot, from my SYSVDLG. Quote Link to comment Share on other sites More sharing options...
MURAl_KMD Posted December 6, 2016 Author Share Posted December 6, 2016 Thank you Dadgad If i am not wrong, CMDECHO is not the reason for the issue. Once a faced problem that most of the lisp programs not working, and traced out that the programs having commands which open dialogs doesn't work. - example : (command "._layer" ....) After doing "Reset Settings to Default" issue was cleared. Not able to find the actual system variable. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted December 6, 2016 Share Posted December 6, 2016 Sorry about that, I am ill-lisperate, but thought that was the one. Glad you were able to get it sorted! Quote Link to comment Share on other sites More sharing options...
MURAl_KMD Posted December 6, 2016 Author Share Posted December 6, 2016 Still i am in search of the cause:) Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted December 6, 2016 Share Posted December 6, 2016 CMDDIA or FILEDIA? Quote Link to comment Share on other sites More sharing options...
asos2000 Posted December 6, 2016 Share Posted December 6, 2016 FILEDIA is what you looking for but it is better to add - next to command (command "_.[b]-[/b]layer" ......) (command "_.[b]-[/b]rename" ......) instead of (command "._layer" ......) (command "._rename" ......) Quote Link to comment Share on other sites More sharing options...
MURAl_KMD Posted December 6, 2016 Author Share Posted December 6, 2016 May be this issue due to some bug. Is there any way to display dialog box while we type following at command prompt. (command "._layer") or (command "._rename") FILEDIA and CMDDIA doesn't do this Already i started to practice (command "_.-layer" ......) (command "_.-rename" ......) Thank you Roy and asos Quote Link to comment Share on other sites More sharing options...
