wimal Posted December 16, 2016 Share Posted December 16, 2016 Cad version 2016. In my cad program above shortcut does not run group on off function. How can I reset it. Quote Link to comment Share on other sites More sharing options...
YZ Posted December 19, 2016 Share Posted December 19, 2016 I think you can set this in the CUI, under "Keyboard Shortcuts" > "Shortcut Keys". There is one there called "Group Selection On/Off". Quote Link to comment Share on other sites More sharing options...
tombu Posted December 28, 2016 Share Posted December 28, 2016 Ctrl+shift+A is Select Similar on my Civil 3D. Ctrl+A was used to toggle groups in DOS and still works in a macro, but is Windows default Select All everywhere else. I added a flyout to the "Object Snap Cursor Menu" Shortcut Menu named $(eval,OSNAP = $(if,$(and,16384,$(getvar,osmode)),"Off","On")) that has a lot of macros that toggle system variables that update their display automatically. One of those macros toggles Group On/Off. Display Name: $(if,$(and,1,$(getvar,pickstyle)),!.)Group Command Name: Toggle Groups Description: Toggle Group Selection Mode Macro: ^A Another macro toggles Display Group as Box with a single grip at the center Display Name: $(if,$(and,2,$(getvar,groupdisplaymode)),!.)GroupBoxDisplay Command Name: GroupBoxDisplay Description: Display Group as Box with a single grip at the center Macro: ^P'setvar;groupdisplaymode;$M=$(if,$(and,2,$(getvar,groupdisplaymode)),0,2) ^P Quote Link to comment Share on other sites More sharing options...
tombu Posted December 28, 2016 Share Posted December 28, 2016 The Keyboard Shortcut to "Toggle Pick Style" which toggles Groups on/off is Ctrl+H If you want it to display and at the command line so you can tell if it's on or off change the macro to ^A Quote Link to comment Share on other sites More sharing options...
