Results 1 to 10 of 10
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    Default run lisp routine error unknown command
    Hello Guys,
    I have an lisp program that search text entity and extract data. however my program come up with an error "unknown command". Please help..
    TIA,
    Dax
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,014
    more than likey that the directory does not exist VLIDE gave up here
    Code:
    (setq file (open "C:\\aut13\\extractedpsvdata.csv" "a"))
        (write-line (strcat filename "," tagNo "," press "," size) file)
              (close file)
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    Quote Originally Posted by BIGAL View Post
    Code:
              (close file)
    Hi BIGAL,
    Thank you for your response. The directory exist, thought my lisp routine was working, but when I executed this to multiple drawings (using script file), it does not moved to the another drawings. I've also notice the "unknown command extractentity (which is in my program), but when I added (command "") or just pressing "enter command" on my program it just executed. I think this error causing the problem that why it did not moved to the another drawings.
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    Hi Guys,
    Anyone here who could help resolve the error..
    Thanks,
    Dax
  5. #5
    Super Member
    not applicable
    Jun 2016
    606
    Maybe you will get more answers if you post a test drawing.
    Exactly explaining what the program should do may also help (why the temporary circle?).
    BricsCAD 18
  6. #6
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    Quote Originally Posted by Roy_043 View Post
    Hi Roy,
    Thanks for your response, there something wrong with my code when executing the lisp program thru .scr file, it gives me a unknown command "wp" which is reside on my lisp. But when this executed manually it just executed cleanly.
    (inside .scr file)
    .OPEN
    "drawing name"
    ZOOM
    A
    (C:EXTRACTPSVDATA)
    this working perfectly when entering manually..
    Regards,
    Dax
  7. #7
    Super Member
    not applicable
    Jun 2016
    606
    OK that is very useful information.
    The problem is caused by the CMDACTIVE variable. It is not zero when a script is running (see the documentation).
    Instead of:
    Code:
    (if (zerop (getvar 'cmdactive))
    Use:
    Code:
    (if (zerop (logand (getvar 'cmdactive) 3))
    BricsCAD 18
  8. #8
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    Instead of:
    Code:
    Use:
    Code:
    Hi Roy,
    After changing the code, its works perfectly... Thanks much!! have your tried to load this kind of lisp to multiple drawings without using third party tools like script pro.. etc.
    Just wondering this is possible :
    - run batch program (open autocad and run .scr file)
    - .scr file will execute .lsp file to create another .scr file that contain list of drawings.
    Sample.
    .OPEN
    "drawing name1"
    (load "lisp program")
    lisp program
    .CLOSE
    Y
    .OPEN
    "drawing name2"
    lisp program
    .CLOSE
    Y
    Regards,
    Dax
  9. #9
    Super Member
    not applicable
    Jun 2016
    606
    Quote Originally Posted by dax View Post
    Probably. But I must say I do not understand the logic behind this approach.
    BricsCAD 18
  10. #10
    Junior Member
    AutoCAD 2014
    Jun 2016
    24
    This is a automation to extract data/attribute from a specific entity, initially I do this with batch program, but prob with this approach is that it open and close autocad instance per drawing, thats why I change it to iterate thru a .scr file. Im planning to have a UI on this on Excel format and the output will be also on Excel. The user for this been able to input text value and directory of the drawings.
    Regards,
    Dax
  1. ;error: Unknown function definition when it is clearly in my lisp.
    By Lee Chu Chu in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Jul 2014, 11:32 pm
  2. LISP - Unknown command for lot of well known LISPs - Solved
    By p0peye in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Nov 2013, 11:38 am
  3. "chamfer" unknown command in lisp routine
    By cso in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Apr 2011, 06:49 pm
  4. Open and Save command causes "Unknown Command" error
    By andythoms in forum AutoCAD General
    Last Post: 12th Nov 2010, 05:00 pm
  5. Error: Unknown command when using the APPLOAD
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 16th Nov 2006, 06:21 pm
