sanjeeve Posted January 14, 2017 Posted January 14, 2017 Anybody extract text from this blocks. new block.dwg Quote
Roy_043 Posted January 14, 2017 Posted January 14, 2017 You can do it with the _ATTEXT command. Quote
gS7 Posted January 15, 2017 Posted January 15, 2017 (edited) Try this link you can extract attributes values http://www.lee-mac.com/macatt.html excellent program by Mr.lee mac and my version (quick and dirty ) (defun c:test (/ s attr tagstr atblks i txtstr txtpos) (vl-load-com) (if (setq atblks (ssget '((0 . "INSERT") (66 . 1)))) (progn (repeat (setq i (sslength atblks)) (setq enm (vlax-ename->vla-object (ssname atblks (setq i (1- i)))) ) (setq attr (vlax-safearray->list (vlax-variant-value (vla-getattributes enm)) ) ) (foreach d attr (setq tagstr (vla-get-tagstring d) txtstr (vla-get-textstring d) txtpos (vla-get-TextAlignmentPoint d) ) (entmake (list (cons 0 "TEXT") (cons 1 (strcat tagstr "=" txtstr)) (cons 10 (vlax-safearray->list (vlax-variant-value txtpos)) ) (cons 40 0.2) (cons 50 0.314159) ) ) ) ) ) ) (princ) ) Edited January 15, 2017 by gS7 Multiple selection Quote
Grrr Posted January 15, 2017 Posted January 15, 2017 Heres my attempt (something like NCOPY for attributes): (defun C:test ( / e AcSpc Props Atts) (setvar 'errno 0) (while (/= 52 (getvar 'errno)) (setq e (car (entsel "\nPick attributed block <exit>: "))) (cond ( (= 7 (getvar 'errno)) (princ "\nMissed.") (setvar 'errno 0) ) ( (and e (/= "INSERT" (cdr (assoc 0 (entget e)))) ) (princ "\nThis is not a block.") ) ( (and e (/= 1 (cdr (assoc 66 (entget e)))) ) (princ "\nThis Block is not attributed.") ) ( e (setq AcSpc (vlax-get-property (vla-get-ActiveDocument (vlax-get-acad-object)) (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))) (setq Props (list 'TextAlignmentPoint 'TextString 'Height 'Rotation 'ScaleFactor 'StyleName 'Alignment 'InsertionPoint)) (setq Atts (mapcar (function (lambda (x) (mapcar '(lambda (p) (vlax-get x p)) Props))) (vlax-invoke (vlax-ename->vla-object e) 'GetAttributes) )) (mapcar '(lambda (x / o) (if (setq o (vla-AddMtext AcSpc (vlax-3D-point '(0. 0. 0.)) 0 "ABC")) (mapcar (function (lambda (a b) (cond ( (= a 'Alignment) (setq a 'AttachmentPoint) (setq b (cadr (assoc b '((7 1) (8 2) (9 3) (10 4) (11 5) (12 6) (13 7) (14 (15 9))))) ) ) (and b (vl-catch-all-apply 'vlax-put (list o a b))) ) ) Props x ) ) ) Atts ) (setvar 'errno 52) ) ); cond ); while (princ) ); defun C:test Still has text justification issues. Quote
satishrajdev Posted January 17, 2017 Posted January 17, 2017 With little variation :- (defun c:test (/ a b) (vl-load-com) (if (setq a (ssget '((0 . "INSERT") (66 . 1)))) (progn (repeat (setq i (sslength a)) (setq b (vlax-ename->vla-object (ssname a (setq i (1- i))))) (foreach x (vlax-invoke b 'getattributes) (entmake (list (cons 0 "TEXT") (cons 1 (strcat (vla-get-tagstring x) "=" (vla-get-textstring x) ) ) (cons 10 (vlax-get x 'textalignmentpoint)) (cons 40 (vla-get-height x)) (cons 50 (vla-get-rotation x)) ) ) ) ) ) ) (princ) ) Quote
