Change VP Layer Colour
Earlzii
Hi,
I need some help I need to create a selection of layers that have a certain keyword in the layername. For the example it is looking for the word TEST.
It should then run the command VPLAYER and change the colour in all viewports for layers that contain the word TEST.
The lisp routine runs fine but does not seem to select anything. I have probably done something wrong in the ssget part but I cannot figure out what I have done.
(defun C:test ( / layerlist)
(setq layerlist (ssget "x" (list (cons 0 "TEST"))))
(command "vplayer" "c" "253" layerlist "")
If any of you guys could help that would be great.
Thanks
Probably need some WCMATCH and an IF statement to do one thing or the other.
But don't ask me how to implement that.
(if (wcmatch (strcase (vla-get-name layer)) "*TEST*")
() ; do nothing if layer exist that contains TEST
Above code should do the trick (or get's you going in the right way).. but it might nog work at all :P.
thanks for the reply.
I've tried the code that you have there and I couldn't get it to work.
I'm going to actually look into the WCMATCH that you suggested and try and figure it out. Thanks for giving me an idea into what to look at.
How about something like this?
(defun GetMatchingLayers (keyword / lays li )
 (setq lays (vlax-get-property (vlax-get-property (vlax-get-acad-object) 'ActiveDocument) 'Layers))
 (vlax-for lay lays
   (if (wcmatch (strcase (vlax-get-property lay 'Name)) (strcat "*" keyword "*"))
     (setq li (append li (list lay)))
 li
Thanks for the reply Hippe. I have a very basic knowledge of lisp and I have no idea what the vlax parts are doing but I've tried running this and I get an error saying too few arguments.
I've tried to add in an else part to the if statement to show an alert saying there are no layers containing the keyword but this didn't solve it. I think the error is in relation to vlax part.
 (vlax-for lay lays
   (if (wcmatch (strcase (vlax-get-property lay 'Name)) (strcat "*" TEST "*"))
(ALERT
"There are no layers containing TEST"
(defun C:vptest (li)
(GetMatchingLayers)
(command "vplayer" "c" "253" li "c" "")
If you just want to change layer colors, I'd go with something like this:
[b][color=BLACK]([/color][/b]defun c:layclr [b][color=FUCHSIA]([/color][/b]/ sc td ln ll[b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]setq sc [b][color=NAVY]([/color][/b]strcase [b][color=MAROON]([/color][/b]getstring [color=#2f4f4f]"\nLAyer Search Phrase:  <TEST>:   "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]if [b][color=NAVY]([/color][/b]= sc [color=#2f4f4f]""[/color][b][color=NAVY])[/color][/b]
     [b][color=NAVY]([/color][/b]setq sc [color=#2f4f4f]"TEST"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]setq td [b][color=MAROON]([/color][/b]tblnext [color=#2f4f4f]"LAYER"[/color] [b][color=GREEN]([/color][/b]not td[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]setq ln [b][color=MAROON]([/color][/b]cdr [b][color=GREEN]([/color][/b]assoc 2 td[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b]
        [b][color=NAVY]([/color][/b]if [b][color=MAROON]([/color][/b]wcmatch ln [b][color=GREEN]([/color][/b]strcat [color=#2f4f4f]"*"[/color] sc [color=#2f4f4f]"*"[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b]
            [b][color=MAROON]([/color][/b]setq ll [b][color=GREEN]([/color][/b]cons ln ll[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.LAYER"[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]foreach l ll
    [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_Color"[/color] 253 l[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]""[/color][b][color=FUCHSIA])[/color][/b]
 [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
I don't know anything about VPLAYER color command. It hasn't been around very long.
Thanks David I have managed to figure out how to change the layers colour with this.
(defun c:LAYTEST ( )
   (vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
           (vl-catch-all-apply 'vla-put-color (list layer 253))
(vl-load-com) (princ)
It is basically Lee Macs code in another forum post and I just changed it from changing the layer name to the colour.
The drawings that I do we split depending on each discipline Civil Mechanical etc. The drawings however contain all the information from each discipline to give the drawing some context but for the Civil drawings the civil information will be in its original colour and everything else is set to colour 253.
All of the information is controlled through xrefs and we have strict rules about changing colours etc. that basically say you have to do it through a Viewport which is where the VPLAYER command comes in.
We usually just bring up the layer manager when in an active viewport and change the colour there for each individual viewport. But this is a bit tiresome and everytime something changes in the design we have to go back through this so I just wanted a Lisp to automatically set the layer colours to save some time as there can be hundreds of drawings some times.
Also forgot to say each layer will have a prefix i.e. CIV for Civil MEC for Mechanical etc. this is what I want the lisp to do search for layers that contain CIV and change the viewport colour to 253 not the actual layer colour.
I think I've cracked it.
(defun c:TEST ( )
       (if (wcmatch (setq laylist (strcase (vla-get-name layer))) "*TEST*")
(command "vplayer" "c" "253" laylist "a" "")
I'm not sure if it's the most efficient way or if there will be any errors in the future after multiple uses etc. but it seems to do the job.
Thanks for the help chaps.
Here's a working version of David's code, modified to step through VPLAYER- I noticed your version is case sensitive, and I like the prompt in David's for other layers
(defun c:layclr (/ sc td ln ll)
 (setq sc (strcase (getstring "\nLAyer Search Phrase:  <TEST>:   ")))
 (if (= sc "")
     (setq sc "TEST"))
 (while (setq td (tblnext "LAYER" (not td)))
        (setq ln (cdr (assoc 2 td)))
        (if (wcmatch ln (strcat "*" sc "*"))
            (setq ll (cons ln ll))))
 (foreach l ll
    (command "vplayer" "c" 253 l "all" ""))
(prin1))
It is a good idea especially if anyone else is going to use this, but for what I need it for it is going to be a bit redundant as we only use specific layers which I will factor into the routine now that I have a working example.
Thanks for your help guys.
Did you look at the code of COLORXLAY?
Could be a nice to make this suitable for these kinds of operations
add ..
(checkbox) VPlayers (when tilemode =0 in modelspace)
(checkbock) layers : * (sc)
This code..
http://www.cadtutor.net/forum/showthread.php?533-Lisp-colour-change-for-all-layers-and-blocks&p=669945&viewfull=1#post669945
