sivapathasunderam Posted January 23, 2017 Share Posted January 23, 2017 Dear colleagues, Some of my dwgs when I open message appears as Xref_LAYOUT_2D.dwg contains 189 annotation scales. It is recommended you open and resave the Xref file to remove excess scales. What I have to do? thanks Siva Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 23, 2017 Share Posted January 23, 2017 Did you try opening and resaving the xref file to remove excess scales? Did you try using the scale list cleanup utility for AutoCAD 2013/2014? Quote Link to comment Share on other sites More sharing options...
sivapathasunderam Posted January 26, 2017 Author Share Posted January 26, 2017 Did you try opening and resaving the xref file to remove excess scales? Did you try using the scale list cleanup utility for AutoCAD 2013/2014? Thanks for suggestion to my thread I have downloaded the scale list cleanup utility for AutoCAD 2013 from Autodesk website Siva Quote Link to comment Share on other sites More sharing options...
