FrancescoITA Posted February 6, 2017 Share Posted February 6, 2017 Hi everybody, i need help....I am looking for two command of VBA of the layout. Some example would be fantastics... The two command are: --> one to increase the dimensions of viewport Increase the viewport.PNG -->the another to set the windows to print through the setting of two point (lower left corner e upper right corner of the area that i want to print) windows to print.PNG Window to print in action.PNG Thank you very much in advance Quote Link to comment Share on other sites More sharing options...
maratovich Posted February 6, 2017 Share Posted February 6, 2017 Create again - there is no time, there is a ready =3$ Quote Link to comment Share on other sites More sharing options...
FrancescoITA Posted February 6, 2017 Author Share Posted February 6, 2017 pls post the link Quote Link to comment Share on other sites More sharing options...
maratovich Posted February 6, 2017 Share Posted February 6, 2017 (edited) pls post the link The preceding your question, I gave an example: http://www.cadtutor.net/forum/showthread.php?99552-VBA-CODE-From-multiple-areas-to-plot-in-model-space-to-create-a-layout-for-each-areas&p=677456&viewfull=1#post677456 Link to the program: https://www.kdmsoft.net/revers.html Write to the author, it will help you on Skype. Edited December 21, 2017 by maratovich Quote Link to comment Share on other sites More sharing options...
FrancescoITA Posted February 6, 2017 Author Share Posted February 6, 2017 maratovich...I don't want a program...i want to know the string that i have to use to do it....so don't advertise! Quote Link to comment Share on other sites More sharing options...
OMEGA-ThundeR Posted February 6, 2017 Share Posted February 6, 2017 What's wrong with making a template (.DWT file) with all the right settings in them? Also setting some 'standaard' page setup options can do the trick. But to be honest i don't really understand the question. You could write a lisp routine with the following command: -plot Most settings that the plot windows has can be done in the commandline. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 7, 2017 Share Posted February 7, 2017 The lisp command line version (COMMAND "-PLOT" "Y" "" "[url="file://\\100B-CLR-PRN03"]100B-CLR-PRN03[/url]" "A3 (297 x 420 mm)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "DesignlaserCOLOUR.ctb" "Y" "n" "n" "n" "N" "N" "y") ) Quote Link to comment Share on other sites More sharing options...
