smr Posted February 8, 2017 Share Posted February 8, 2017 Hi all I am trying to insert a block from a known file location into a drawing using a AutoCAD menu button to load a vba code I have successfully done this but I can only have the block inserted at coordinates that are either entered by the user on the keyboard or set in the code. I am looking to have it be selectable by the user by clicking the mouse with it floating on the cursor (ie Specify on-screen) basically like what happens when you insert a block. If anyone can help that would be great. code attached fyi code.txt Quote Link to comment Share on other sites More sharing options...
maratovich Posted February 8, 2017 Share Posted February 8, 2017 Object methods in VBA is not implemented You can only use Lisp expression SendCommand and functions: Option Explicit '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Function IsBlockExist(bName As String) As Boolean Dim oBlock As AcadBlock IsBlockExist = False For Each oBlock In ThisDrawing.Blocks If StrComp(oBlock.Name, bName, vbTextCompare) = 0 Then IsBlockExist = True End If Next End Function '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Function IsLayerExist(lName As String) As Boolean Dim oLayer As AcadLayer IsLayerExist = False For Each oLayer In ThisDrawing.Layers If StrComp(oLayer.Name, lName, vbTextCompare) = 0 Then IsLayerExist = True End If Next End Function '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Sub InsertWithGhostImage() Dim blkName As String, layName As String Dim strPt As String, comStr As String blkName = InputBox(vbCrLf & "Block name to insert:", "Insert Block") If blkName = vbNullString Then Exit Sub If Not IsBlockExist(blkName) Then MsgBox "Block " & Chr(34) & blkName & Chr(34) & " does not exist" Exit Sub End If layName = InputBox(vbCrLf & "Layer name to insert block on:", "Insert Block", "0") If Not IsLayerExist(layName) Then MsgBox "Layer " & Chr(34) & layName & Chr(34) & " does not exist" Exit Sub End If With ThisDrawing On Error GoTo Err_Control .Utility.Prompt vbCrLf & " Specify insertion point of block >>" comStr = "(command " & _ Chr(34) & "._-insert" & Chr(34) & _ vbCr & Chr(34) & blkName & _ Chr(34) & " pause " & vbCr & _ Chr(34) & "1" & Chr(34) & _ vbCr & Chr(34) & "1" & Chr(34) & _ vbCr & Chr(34) & "0" & Chr(34) & ")" .SendCommand comStr & vbCr DoEvents Dim oSpace As AcadBlock Dim oblkRef As AcadBlockReference If .ActiveSpace = acModelSpace Then Set oSpace = .ModelSpace Else Set oSpace = .PaperSpace End If Set oblkRef = oSpace.Item(oSpace.Count - 1) End With Exit_Here: Exit Sub Err_Control: MsgBox Err.Description Resume Exit_Here End Sub Code is taken from here http://forum.dwg.ru/showthread.php?t=23161 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 8, 2017 Share Posted February 8, 2017 This may be useful its in a menu but the DRAG may be want you want ^C^C-INSERT P:/AUTODESK/LISP/SETOUT DRAG \1 1 0 Quote Link to comment Share on other sites More sharing options...
smr Posted February 15, 2017 Author Share Posted February 15, 2017 Thank you for your reply’s I have managed to make this work by calling a LISP expression from the CUI menu macro button I think it is more of a work around but works for what I need it to do LISP command is: (defun c:sa () ; moves block that was just inserted (command "move" "l" "" "0,0,0" "pause") (princ) ) CUI menu macro command is ^C^C-vbarun SMR_CableLadder.dvb!Module1.CableLadderMenu^C^C_sa This loads my vba user form for cable ladder (I then select what I need) It inserts it @ 0,0,0 in the current drawing Then calls the “SA” lisp move command which moves the last inserted block Simples Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 15, 2017 Share Posted February 15, 2017 Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[NOPARSE] Your Code Here[/NOPARSE] = Your Code Here Quote Link to comment Share on other sites More sharing options...
