samifox Posted February 9, 2017 Share Posted February 9, 2017 hi im using acad 2010, I find wblock (command) most useful to proxy out a performance issued drawings. as you know after filtering out a drawing with wblock command the drawing loses about 95% of its total weight. The problem is what I'm gonna do when I have lots of xref connected? how to wblock all xref connected to a host drawing? any idea? Thanks S Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 9, 2017 Share Posted February 9, 2017 If you remain in the same folder, it shouldn't matter, but it may depend on the path type used and where the xreffed files are located, they should be in a pathed folder or the same folder I do believe. The XREF Manager can repath them if needed. For drawing clean up see THIS. Please stop putting all of your threads in the General Forum, I am getting tired of moving them, I have relocated this one to the AutoCAD Drawing Management & Output Forum. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 9, 2017 Share Posted February 9, 2017 Adherence to good CAD drafting procedures would avoid 95% of the problem in the first place thus negating the reason to use the WBlock command in the first place. Quote Link to comment Share on other sites More sharing options...
