Travaci Posted February 14, 2017 Share Posted February 14, 2017 Hi everyboady. İ want to copy tags with field. Already i do, but i have a problem When i do this, i dont want to use "command" and "regen". Is this possible ? (defun c:axx (/ *error* ss ob n at pn pv) (vl-load-com) (defun *error* (msg) (if (not (wcmatch (strcase msg t) "*cancel*,*exit*")) (princ (strcat "\nError: " msg))) (if ss (redraw (ssname ss 0) 4)) (princ)) (if (setq ss (ssget ":s" (list (cons 0 "insert")))) (progn (redraw (ssname ss 0) 3) (if (setq ob (ssget (list (cons 0 "insert")))) (progn (vla-startundomark (vla-get-activedocument (vlax-get-acad-object))) (repeat (setq n (sslength ob)) (setq n (1- n)) (foreach at (vlax-invoke (vlax-ename->vla-object (ssname ss 0)) 'Getattributes) (setq pn (vlax-get-property at 'TagString) pv (strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vlax-get-property at 'ObjectId)) ">%).TextString>%")) (foreach at (vlax-invoke (vlax-ename->vla-object (ssname ob n)) 'GetAttributes) (if (eq (vla-get-TagString at) pn) (vlax-put-property at "TextString" pv)))) (vl-cmdf "._updatefield" (ssname ob n) "") ) (vla-endundomark (vla-get-activedocument (vlax-get-acad-object))) (redraw (ssname ss 0) 4) ) ) ) ) (if ss (redraw (ssname ss 0) 4)) (princ) ) Quote Link to comment Share on other sites More sharing options...
Travaci Posted February 17, 2017 Author Share Posted February 17, 2017 Noboady now ? Quote Link to comment Share on other sites More sharing options...
