I have already created a lisp that verify if a layer is frozen. If true, an other layer is frozen too.
(if (= (vla-get-Freeze layer1) :vlax-true) (command "VPlayer" "FREEZE" "layer2" "" ""))
How can I do that in vplayer? it doesnt seem to work the same?
  • 3 weeks later...
Is my question clear? Nobody would have an idea?
What I need to do is to check the vplayerstate of a specific layer before contolling the vplayerstate.
Thank you for your feedback.
VPlayers.lsp - http://jtbworld.com/autocad-vplayers-lsp
By Jimmy Bergmark - Copyright © 1997-2006 JTB World, All Rights Reserved
Website: http://www.jtbworld.com - E-mail: info@jtbworld.com
DESCRIPTION
c:SaveVPlayers - Save frozen viewport layers to file
c:LoadVPlayers - Load and restore frozen viewport layers from file
c:CopyVPlayers - Select one viewport and get the layersettings
then select the destination viewport(s) to inherit these
Works perfectly Thank you!
(setq vplayer-LIST (ACET-VIEWPORT-FROZEN-LAYER-LIST (ACET-CURRENTVIEWPORT-ENAME)))
(if (MEMBER "Layer1" vplayer-LIST)(command "VPlayer" "FREEZE" "Layer2" "" ""))
