smithjarid54 Posted February 16, 2017 Share Posted February 16, 2017 Hello all, I'm new to using LISP and was wondering if there was a LISP for inserting multiple blocks by name. The company I work for deals with lots of cranes, so we have a large block library. Ideally I would like to input the crane make, then model, then boom, and then snatch block. In doing so, it will grab all the individual blocks as listed from our library and insert them into the DWG. Possibly using a user defined insertion point for insertion. I'll take any advice or help I can get. Thanks, Jarid Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted February 16, 2017 Share Posted February 16, 2017 How does a single crane translate to multiple blocks? Quote Link to comment Share on other sites More sharing options...
halam Posted February 16, 2017 Share Posted February 16, 2017 Sorry Roy_043, hope you don't find me rude interfering with my replies. Seems a bit logical to me. Many different possibilities, each dependent what the site on the job is. Intresting question , welcome here and congrats with your first post ..i'm thinking scripts (.scr) for certain scenario's.. Excel can help.. https://www.google.nl/search?q=components+crane+erection&safe=active&rls=com.microsoft:nl-NL&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjDxfXH05XSAhXMOxoKHflVB3EQsAQIGw&biw=1298&bih=726 Quote Link to comment Share on other sites More sharing options...
Roy_043 Posted February 16, 2017 Share Posted February 16, 2017 Let me try to explain better: It is obvious that the OP wants to work with multiple crane models, but what does he mean by 'grab all the individual blocks': Do several (3D?) blocks have to be assembled to create the crane? Or does each model perhaps have a plan view and multiple side views? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 17, 2017 Share Posted February 17, 2017 (edited) There is no problem inserting blocks by a combination of strings. An example 12 50 12mm bolt 50mm long would insert "Bolt1250". Another we have scale bars like "SC10050" which is 100 ver 50 hor. (setq blkname (strcat "bolt" (rtos (getint "enter diameter") 2 0)((rtos (getint "enter length") 2 0))) For the opp would need a list of blocks to be inserted as a collection, insert points to have some rules also. Crane52 is entered add motor12 + gantry3 + wheels 4 etc (list "Crane52" "motor12" "gantry3" "wheels 4") Probably the easiest way is think of it as a parts list make a text file with all the parts. Crane1 part1 part2 part3 Crane2 part1 part22 part3 Edited February 17, 2017 by BIGAL Quote Link to comment Share on other sites More sharing options...
jesset Posted February 17, 2017 Share Posted February 17, 2017 You may be better served using tool palettes Quote Link to comment Share on other sites More sharing options...
