Results 1 to 5 of 5
    Senior Member gS7's Avatar
    gS7's Computer Details
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    gS7's Discipline Details
    Drafts man / Surveyor
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    Question Confusion with lambda function
    Hi Guys
    How to Create Line for coordinates from list using lambda function
    Please need help for solve this
    Code:
    (defun c:test(/ lst )
          (setq lst '((1515.32 999.613 0.0) (2314.23 1081.97 0.0) (1690.57 752.536 0.0)
    		  (2458.55 829.747 0.0) (1685.41 474.574 0.0) (2716.26 443.689 0.0))
          (mapcar (function (lambda (x y)
    			      (command "line" x y "") ????
    	      lst
    Ganesh Shetty
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,071
    Code:
    (mapcar
      '(lambda (x y) (entmakex (list (cons 0 "LINE") (cons 10 x) (cons 11 y))))
      lst
      (append (cdr lst) (list (last lst)))
    Or:
    Code:
    (mapcar
      '(lambda (x) (entmakex (list (cons 0 "LINE") (cons 10 (car x)) (cons 11 (cadr x)))))
      (mapcar 'list lst (append (cdr lst) (list (last lst))))
    EDIT: Or if you use LM's entmake functions, then you could just
    Code:
    (defun LWPoly (lst cls) ; LM
      (entmakex
        (append
          (list
            (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity")
            (cons 100 "AcDbPolyline") (cons 90 (length lst)) (cons 70 cls)
          (mapcar (function (lambda (p) (cons 10 p))) lst)
    do this:
    Code:
    (LWPoly lst 0)
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    Grrr
    That was awesome and i don't want to create only 3 Line Entity's for example '(1 1) '(2 2) '(3 3) Please waiting for your reply
    Ganesh Shetty
    Super Member
    Multi-disciplinary
    AutoCAD 2015
    Nov 2013
    1,071
    Quote Originally Posted by gS7 View Post
    Grrr
    If you want to create lines from a point list, you have to group the items so each one consists of 2 points (a line is defined of 2 points) :
    Instead of such list
    Code:
    you'll have to use:
    Code:
    (list
      '((1 1) (2 2)) ; line #1
      '((2 2) (3 3)) ; line #2
      '((3 3) (1 1)) ; line #3 (if you want to close the shape)
  5. #5
    Windows Xp sp3
    4 GB
    Viewsonic
    Surveying
    Surveying
    AutoCAD 2009
    May 2012
    Udupi,INDIA
    238
    Quote Originally Posted by Grrr View Post
    Code:
    you'll have to use:
    Code:
    (list
    Grrr thank you It is helped me lot
    Ganesh Shetty
  1. Call a function in mapcar lambda function
    By Shakto in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Oct 2014, 05:07 am
  2. trying to lambda-ize a function into another
    By Jef! in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Mar 2014, 04:59 pm
  3. lambda , function , mapcar , apply , foreach : explained
    By samifox in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Sep 2013, 09:56 pm
  4. lambda function
    By giskumar in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Apr 2011, 01:33 pm
  5. Function (Lambda...??
    By chulse in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th May 2010, 05:34 pm
