reynaldomalasaga Posted February 20, 2017 Posted February 20, 2017 Good day Sir/Maam, Can any one teach me how to modify this code.. i need to select a text in my drawing and that selected text will be added .. please help me!!! :cry::cry::cry: this is the code (defun c:addn ( / ss) (vl-load-com) (if (and (setq ss (ssget "X" (list (cons 0 "*text")))) (setq amt (getreal "\nIsuwat kung pila ang gusto nimo e puno na numero: "))) (progn (mapcar '(lambda (z) (vla-put-textstring z (rtos (+ (atof (vla-get-textstring z)) amt) 2 3))) (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))) ) ) (princ) ) Quote
BIGAL Posted February 20, 2017 Posted February 20, 2017 Something like this text only ;Adds a fixed amount to a number (Alert "TO USE JUST TYPE A2LM") (DEFUN c:A2LM ( / el en a v1 v2 ss) (setvar "cmdecho" 1) (setq olddimzin (getvar "Dimzin")) (setvar "dimzin" 0) (if (not AH:getval) (load "getval")) (ah:getval "Enter ht adjust.." 10 (setq v2 (Atof item)) (setq ss (ssget (list (cons 0 "Text")))) (setq len (sslength ss)) (setq x 0) (repeat len (setq en1 (ssname ss x)) (setq el1 (entget en1)) (setq v1 (atof (cdr (assoc 1 el1)))) (setq a (+ v1 v2)) (setq b (rtos a 2 3)) (setq el (subst (cons 1 b) (assoc 1 el1) el1)) (entmod el) (setq x (+ x 1)) ) ; repeat (setvar "cmdecho" 1) (setvar "dimzin" olddimzin) (princ) ); END DEFUN ;; Input Dialog box with variable title ;; By Ah June 2012 ;; code (ah:getval "LINE 1" 6 5) (defun AH:getval (title width limit / fo) (setq fo (open "C:\\acadtemp\\getval.dcl" "w")) (write-line "ddgetval : dialog {" fo) (write-line " : row {" fo) (write-line ": edit_box {" fo) (write-line (strcat " key = " (chr 34) "key1" (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) title (chr 34) ";" ) fo) (write-line (strcat " edit_width = " (rtos width 2 0) ";" ) fo) (write-line (strcat " edit_limit = " (rtos limit 2 0) ";" ) fo) (write-line " is_enabled = true;" fo) (write-line " }" fo) (write-line " }" fo) (write-line "ok_only;}" fo) (close fo) (setq dcl_id (load_dialog "c:\\acadtemp\\getval")) (if (not (new_dialog "ddgetval" dcl_id)) (exit)) (action_tile "key1" "(setq item $value)(done_dialog)") (mode_tile "key1" 2) (start_dialog) ; returns the value of item ) Quote
SLW210 Posted February 20, 2017 Posted February 20, 2017 I moved your thread to the AutoLISP, Visual LISP & DCL Forum, please post in the appropriate forum. Please read the Code Posting Guidelines and edit your Code to be included in Code Tags.[NOPARSE] Your Code Here[/NOPARSE] = Your Code Here Quote
reynaldomalasaga Posted February 21, 2017 Author Posted February 21, 2017 thank u sir .. .. :D... hope u will help me nxt time .. Quote
reynaldomalasaga Posted February 21, 2017 Author Posted February 21, 2017 SORRY SIR SLW210.. Thank u for reminding me sir.. sorry .. Quote
