masterfal Posted February 22, 2017 Share Posted February 22, 2017 Hi All, I'm trying to create a lisp routine to run the centerline command then select the line just generated and explode it. I can get it to create the centerline, and then pick the line (defun c:clxo () (command "centerline" pause pause) (setq sel1 (ssget "l")) (sssetfirst nil sel1) (princ) ) but when i add the explode line into it, it doesn't explode.. what am i missing? (defun c:clxo () (command "centerline" pause pause) (setq sel1 (ssget "l")) (sssetfirst nil sel1) (command "explode") (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 23, 2017 Share Posted February 23, 2017 You can not explode a linetype, do you want individual line repeating sequences ? There may be a way with a different command. A easy way of last object is use (setq sel1 (entlast)) in your case why not "explode" "last" "" Quote Link to comment Share on other sites More sharing options...
masterfal Posted February 23, 2017 Author Share Posted February 23, 2017 centerline is an object type (as well as linetype.. bit confusing I know). in 2017 theres a default command called 'centerline' after running it you click one line, click another line and it draws a line central as a 'centerline' . my issue with it is that you are unable to offset this centerline (or do a few other modifications) unless its exploded and turned into a regular line. thought I could save time by combining it all. ie. run the centerline command, then explode that line. then after its exploded I can run this double offset lisp I've got which offsets a line equally on both sides Quote Link to comment Share on other sites More sharing options...
CHLUCFENG Posted February 23, 2017 Share Posted February 23, 2017 Very interesting. You made me open 2017 and use the new command CENTERLINE. With that being said, I see that the centerline command asks the user to select a first line, then a second line, and places a centerline object between them. A new entity type I was unaware of, and that cannot be offset. Interesting. Command: CENTERLINE Select first line: Select second line: Command: Command: LI LIST 1 found CENTER LINE Layer: "0" Space: Model space Color: BYLAYER Linetype: "CENTER2" Handle = 1010a33 Associative: Yes Start Extension = 0.120000, End Extension = 0.120000 From point, X= 3576.995446 Y= 1318.941228 Z=0.000000 To point, X= 3838.233877 Y= 1057.702796 Z=0.000000 Length = 369.446933 Command: O OFFSET Current settings: Erase source=No Layer=Source OFFSETGAPTYPE=0 Specify offset distance or [Through/Erase/Layer] <Through>: Specify second point: Select object to offset or [Exit/Undo] <Exit>: Cannot offset that object. So, I thought I would treat this similar to adding lines to a selection set to generate a polyline afterward, and dug up a snippet from an old code, and it works: (progn (setq Center1 (entlast)) (setq ssCenterline (ssadd)) (ssadd Center1 ssCenterline) (vl-cmdf "_.explode" ssCenterline) ) Quote Link to comment Share on other sites More sharing options...
masterfal Posted February 23, 2017 Author Share Posted February 23, 2017 genius! thanks so much. now I just need to work out how to run this double offset command on the line after its been exploded. not to sure how to continue the routine to include below.. (defun c:DOF (/ a b b1 p1 d pckbox) (setq d 20 p1 nil pee (/ pi 2)e 3 pckbox (getvar "pickbox")line " ") (if(= #parof nil)(setq #parof(/(getvar "viewsize")10))) (princ "\nCurrent offset <")(princ #parof) (setq answer(getstring ">: ")) (if (/= (atof answer) 0.0)(setq #parof(atof answer))) (princ line) (setvar "pickbox" pckbox) (setq ent(entsel "\nPick the line: ")) (setq point(cadr ent)) (princ line) (setq side(getpoint "\nPick an offset side: ")) (setq dist(distance side point))(setq ang(angle side point)) (if(or(or(< ang 0.78)(> ang 5.5))(and(> ang 2.35)(< ang 3.92))) (setq ang(- 0 ang))(setq ang(- pi ang)) );end if (setq other(polar point ang dist)) (command "offset" #parof ent side ent other "") (entdel(car ent)) (setvar "pickbox" pckbox) (prin1) ) (Prompt "\nType DOF to envoke the command") Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 23, 2017 Share Posted February 23, 2017 A simple thing in offset to have both sides is to use a -ve value, just take the start and end point direction does not matter use polar for a point at 90 off line then just do offset pt val then offset pt -val A right and left will appear. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 23, 2017 Share Posted February 23, 2017 hijacking the thread for one second - the CENTERLINE command (2017) is great to create a bisector of two angled lines. And they are constrained to stay between the two lines, so if you drag an end point of one line the CENTERLINE will stay centered. You can also bisect between the CENTERLINE and the original line and any CENTERLINEs stay centered between the objects used to create them. now back to regular programming... (pun intended) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 24, 2017 Share Posted February 24, 2017 This is some lisps out there for 2 plines create a new line centrally. Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted February 24, 2017 Share Posted February 24, 2017 This is some lisps out there for 2 plines create a new line centrally. Old thread similar "Centerline" multiple selection but restriction for LINE entity only Quote Link to comment Share on other sites More sharing options...
