Results 1 to 1 of 1
    Senior Member
    AutoCAD 2015
    Sep 2005
    Leeds, England
    248
    Default Cloud rendering (RENDERONLINE) nested block material issues
    Hi Guys
    I have been using cloud rendering from AutoCAD since the feature was released and reproting bugs to the development team along the way.
    One of of the most fundamental issues i have encountered is the loss of materials from blocks when nested inside xrefs.
    Heres my model set up:
    I have a model of my home that i use to test the rendering capabilities at each new release, Each room in the house is a separate drawing all xref'd together into a drawing containing only cameras/lights and a geographic location. Inside each of the rooms i have blocks for various pieces of decor/furniture etc.
    The problem is, the translation engine is not passing the information to the cloud correctly resulting in missing materials.
    Here's a draft render (low quality freebie) showing a picture frame which is missing its picture:
    Rendering the objects from within the block is fine:
    Anyone else running into this issue, who have a workaround (without having to explode all my blocks in my model)?
  1. add a rendering material to a multiview block
    By jlsfagan in forum Architecture & ADT
    Last Post: 3rd May 2015, 04:33 pm
  2. Nested Blocks and Purge Issues
    By Casio47 in forum AutoCAD Drawing Management & Output
    Last Post: 20th Oct 2014, 02:42 pm
  3. Cloud based rendering service?
    By Lewis C in forum Autodesk Inventor
    Last Post: 25th Sep 2012, 10:18 am
  4. Image fails to render with Autodesk Cloud Rendering
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 26th Sep 2011, 03:30 am
  5. ACAD 2009 Rendering issues...Autodesk claims Hardware issues
    By eric_monceaux in forum Hardware & Operating Systems
    Last Post: 22nd Jan 2009, 02:36 pm
