rajib_dhk143 Posted March 2, 2017 Share Posted March 2, 2017 Hello I just started working in a fire detection and protection company. I never used autocad before. I just installed autocad 2014 in my laptop. How can I start learning fire alarm system design? I saw some design there smoke detector, heat detector, manual call point, control module, control panel etc are shown. I u understand the spacing between detectors but I couldn't find the symbols of these devices in autocad 2014. For example the symbol of smoke detectors are a green circle inside SD is written. Where I can find these symbol in autocad 2014? Suppose I open a building architecture CAD drawing then how I can find the detectors symbol and how to connect them. Please explain me step step procedure as I never used autocad before. Thanks Quote Link to comment Share on other sites More sharing options...
mikekmx Posted March 2, 2017 Share Posted March 2, 2017 there are none that i know of included with autocad. i used to do FA design. best thing is to make your own. Look into making them dynamic & use them from a Tool Palette with properties set so they always end up on the correct layer. pm me your email & i will send my ones. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 2, 2017 Share Posted March 2, 2017 Shouldn't you first learn how to use AutoCAD before you start designing? AutoCAD does not ship with many symbols and the ones that are included do not cover the field you are working in. The few ways of obtaining symbols that I know of are... 1. Create your own. 2. Rely on the generosity of others and hope someone gives you a copy of the symbols they created. 3. Do an online search and hope you can find symbols that work inside AutoCAD and that you can download them for free. 4. Buy a symbol library. Looks like number 2 is where you have landed at the moment. If you don't get all the symbols that you will end up needing then my advice would be to create the missing symbols using the ones you have as a guide for doing so. mike: The OP does not have enough posts under his belt to PM you. Quote Link to comment Share on other sites More sharing options...
rajib_dhk143 Posted March 2, 2017 Author Share Posted March 2, 2017 mujahid.islam85@gmail.com This is m email@mikekmx Quote Link to comment Share on other sites More sharing options...
welldriller Posted March 3, 2017 Share Posted March 3, 2017 You might want to check this out. http://www.cadtoolsonline.com/elecsym.htm I has fire alarm horn symbol Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted March 6, 2017 Share Posted March 6, 2017 Notification blocks. Notification Wall Mount System Sensor.dwg NOTIFICATION CEILING MOUNT.dwg Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted March 6, 2017 Share Posted March 6, 2017 Ok they finally loaded I couldn't type a message and load blocks very weird. These are blocks I made for my drawings, they are dynamic but easy to use once you play with them. I created visibility states so I wont have to kept inserting different blocks for the different size candela. I have more blocks I can upload just kept watching this thread. Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted March 6, 2017 Share Posted March 6, 2017 You can make blocks out of this one and edit them how you like. FIRE ALARM EQUIPMENT.dwg Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted March 6, 2017 Share Posted March 6, 2017 You will need this one it's a photo electric smoke detector with dynamic properties. You can place this and it will have the 30 foot makers and a marker for 21 foot off a wall. Play around with what I gave you and if you have any questions just post them here. photosmokeanalog.dwg Quote Link to comment Share on other sites More sharing options...
bluessdjs Posted March 8, 2017 Share Posted March 8, 2017 good for the files ,tks Quote Link to comment Share on other sites More sharing options...
Kash Posted November 12, 2017 Share Posted November 12, 2017 Hi Mike, Please forward me your fire alarm symbols. It will be much appreciated. My email is kashen@telkomsa.net. Many thanks Mike. Quote Link to comment Share on other sites More sharing options...
Aamir Posted August 9, 2019 Share Posted August 9, 2019 On 02/03/2017 at 21:04, mikekmx said: there are none that i know of included with autocad. i used to do FA design. best thing is to make your own. Look into making them dynamic & use them from a Tool Palette with properties set so they always end up on the correct layer. pm me your email & i will send my ones. Please send me a fire alarm system riser diagram and how to make a block and create wires to interconnect them.i have interview in a week please help me out. Quote Link to comment Share on other sites More sharing options...
CADTutor Posted August 10, 2019 Share Posted August 10, 2019 On 09/08/2019 at 12:29, Aamir said: Please send me a fire alarm system riser diagram and how to make a block and create wires to interconnect them.i have interview in a week please help me out. mikekmx hasn't visited this forum in the last two years. Unlikely you'll get a response. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 12, 2019 Share Posted August 12, 2019 It may not be such a good idea to apply for a job that you don't know how to do and expect to learn it in a week. Quote Link to comment Share on other sites More sharing options...
