CadFrank Posted March 2, 2017 Share Posted March 2, 2017 Hi, I'm trying to figure out how to access The VisibiltyState Using C# This is the code I found on Google Search : [CommandMethod("DBP")] static public void DynamicBlockProps() { Document doc = Application.DocumentManager.MdiActiveDocument; Database db = doc.Database; Editor ed = doc.Editor; PromptStringOptions pso = new PromptStringOptions( "\nEnter dynamic block name or enter to select: " ); pso.AllowSpaces = true; PromptResult pr = ed.GetString(pso); if (pr.Status != PromptStatus.OK) return; Transaction tr = db.TransactionManager.StartTransaction(); using (tr) { BlockReference br = null; // If a null string was entered allow entity selection if (pr.StringResult == "") { // Select a block reference PromptEntityOptions peo = new PromptEntityOptions( "\nSelect dynamic block reference: " ); peo.SetRejectMessage("\nEntity is not a block."); peo.AddAllowedClass(typeof(BlockReference), false); PromptEntityResult per = ed.GetEntity(peo); if (per.Status != PromptStatus.OK) return; // Access the selected block reference br = tr.GetObject( per.ObjectId, OpenMode.ForRead ) as BlockReference; } else { // Otherwise we look up the block by name BlockTable bt = tr.GetObject( db.BlockTableId, OpenMode.ForRead) as BlockTable; if (!bt.Has(pr.StringResult)) { ed.WriteMessage( "\nBlock \"" + pr.StringResult + "\" does not exist." ); return; } // Create a new block reference referring to the block br = new BlockReference( new Point3d(), bt[pr.StringResult] ); } BlockTableRecord btr = (BlockTableRecord)tr.GetObject( br.DynamicBlockTableRecord, OpenMode.ForRead ); // Call our function to display the block properties DisplayDynBlockProperties(ed, br, btr.Name); // Committing is cheaper than aborting tr.Commit(); } } private static void DisplayDynBlockProperties( Editor ed, BlockReference br, string name ) { // Only continue is we have a valid dynamic block if (br != null && br.IsDynamicBlock) { ed.WriteMessage( "\nDynamic properties for \"{0}\"\n", name ); // Get the dynamic block's property collection DynamicBlockReferencePropertyCollection pc = br.DynamicBlockReferencePropertyCollection; // Loop through, getting the info for each property foreach (DynamicBlockReferenceProperty prop in pc) { // Start with the property name, type and description List<string> activeVisibility = new List<string>(); if(prop.PropertyName == "Choisir") { ed.WriteMessage("\nProperty Type Code : " + prop.PropertyTypeCode.ToString()); ed.WriteMessage("\nProperty Value : " + prop.Value.ToString()); ed.WriteMessage("\nProperty UnitsType : " + prop.UnitsType.ToString()); } } } } The thing is the position of the visibilityState changes from different blocks. Anyone have a suggestion to help me out? Quote Link to comment Share on other sites More sharing options...
