russell84 Posted March 3, 2008 Posted March 3, 2008 hey again guys I'm looking for a little lisp that i can expand on to suit our standard layers I'm looking for a lisp that can setup new layers in a drawing - names - colors and linetypes But if a layer name already exists dont ask the user to redefine Is there an existing lisp that someones knows about? Cheers Quote
azzro10 Posted March 3, 2008 Posted March 3, 2008 Why dont you just setup a template file with all your standard layers created in it? Quote
russell84 Posted March 3, 2008 Author Posted March 3, 2008 I have already set up one - but everyone wants a simple button to import layers. Thanks though \ Quote
russell84 Posted March 3, 2008 Author Posted March 3, 2008 and i would rather set it up using a lisp for adding layers than bringing in a template Any ideas? Whats the function in a lisp to bring in a layer set its color and linetype and i'll write the rest and post it back for you to pick it to pieces and advise me on all the errors i make ha Cheers Quote
lpseifert Posted March 3, 2008 Posted March 3, 2008 It would be easier to drag the layers from your template using Design Center, but this should get you started... (command "-layer" "m" "[color=Red]layername[color=Black]" "c" "[color=Red]color[color=Black]" "" "l" "[color=Red]linetype[color=Black]" "" "") [/color] [/color][/color][/color][/color][/color] Quote
russell84 Posted March 4, 2008 Author Posted March 4, 2008 i was thinking of using something like this to import layers and set them up - but doing this for each layer would be alot of work for the pc - is there a easier way of doing it or should i just resolve to creating a lisp to import a template file and delete it thus setting up all layers etc any ideas? Cheers (if(not(tblsearch "LTYPE" "EX_GAS")) (command "-linetype" "_l" "EX_GAS" "services" "") ); end if (if(not(tblsearch "LAYER" "EXSRV_GAS")) (command "-layer" "new" "EXSRV_GAS" "Color" 251 "EXSRV_GAS" "LTYPE" "EX_GAS" "EXSRV_GAS" "") );end if Quote
ASMI Posted March 4, 2008 Posted March 4, 2008 Look at this function: (defun CreateLayers(layLst / layCol nLay) (vl-load-com) (setq layCol(vla-get-Layers (vla-get-ActiveDocument (vlax-get-Acad-object)))) (foreach itm layLst (if (not(vl-catch-all-error-p (setq nLay(vl-catch-all-apply 'vla-Add (list layCol(car itm)))))) (vla-put-Color nLay(cadr itm)) ); end if ); end foreach (princ) ); end of CreateLayers And try it with list '(("LayerName1" Color)...): (CreateLayers '(("MyLayer1" 1)("MyLayer2" 2)("MyLayer3" 3))) Quote
russell84 Posted March 4, 2008 Author Posted March 4, 2008 Thankyou once again asmi - i will look at this method Cheers mate Quote
N_461 Posted July 14, 2010 Posted July 14, 2010 So how can the routine load linetypes? i see from the code you can specify the layer, colour, and line type name...does it pull from the acadiso.lin? or acad.lin? can you specify where it loads from? Just starting to learn lisps ... thanks! Quote
fixo Posted July 14, 2010 Posted July 14, 2010 So how can the routine load linetypes? i see from the code you can specify the layer, colour, and line type name...does it pull from the acadiso.lin? or acad.lin? can you specify where it loads from? Just starting to learn lisps ... thanks! Check MEASUREINIT system variable See Help ~'J'~ Quote
N_461 Posted July 14, 2010 Posted July 14, 2010 i found as long as the lin file is in the working directory it pulls from that. I dont want to change the MEASUREINIT system variable. Im more concerned (now) with figuring out the spacing of the coding for the layers. I've been having a rough go so far. It was working then it stopped and i've been getting syntax errors. Im trying to play with the (mapcar 'MkLay .... part of the lisp. instead of listing in columns can i run a series of MkLay sections? I started with: (there are spaces they just didnt carry through to this post....): (defun c:DoLayers ( / ) (vl-load-com) (mapcar 'MkLay '( "CEN" "DIMS" "HAT" "HID" "LOGO" "OBJ" "PAPER" "PHAN" "TITLE" "TXT") ; Name [str] '( 6 1 3 4 176 2 5 6 176 7 ) ; Colours [int] '("CENTER" nil nil "HIDDEN" nil nil "PHANTOM" "PHANTOM" nil nil ) ; LineType [str] '( "018" "018" "018" "015" "009" "040" nil "018" nil nil ) ; LineWeight [str] 0.18 = "018" '( T T T T T T nil T T T )) ; Plottable (T or nil) ....but am trying to make it simpler to add a whole bunch of layers and colours. I only have notepad to edit ...any suggestions? Quote
