lil_nemo Posted August 26, 2008 Posted August 26, 2008 I am running 2005 ADT. In certain drawing, but not all the edges of my text appear very rough. It doesn't seem to have much effect on the plotting, but it tears at the eye and is distracting. I think its some kind of variable because it doesn't occur is every drawing. When I open up an MTEXT editor the text looks correct. Any ideas? Quote
dumfatnhappy Posted August 26, 2008 Posted August 26, 2008 check your viewres? try bumping it up Quote
c_moore47102 Posted August 16, 2012 Posted August 16, 2012 (edited) Hello, I realize this is a little late, but better late than never. I had the exact problem and this is how you should fix it: - set z-value of the text to "0" - set text oblique angles to "0" - set text width to "0" Known causes: - Panning within 3Dorbit Macro: (to set z-value to "0") ^C^C_.Dview;;_Point;0,0,0;0,0,1;; I'll also include some screenshots of my issue and what probably is yours as well. One is what the text should look like and one is portraying the problem. Cheers, Edited August 16, 2012 by c_moore47102 Quote
