chulse Posted September 10, 2008 Share Posted September 10, 2008 Is there a way to merge multiple mtext objects into a single mtext? Thanks Quote Link to comment Share on other sites More sharing options...
Strix Posted September 10, 2008 Share Posted September 10, 2008 can you explain that a bit further? do you mean if (for instance) somebody has added a second block of Mtext as a second line instead of editing the existing and using a carriage return? Quote Link to comment Share on other sites More sharing options...
sparklerach Posted September 11, 2008 Share Posted September 11, 2008 In express tools, you can convert text to MText. So you could explode your MTexts first to single line text and then convert them all together back to Mtext Quote Link to comment Share on other sites More sharing options...
Dipali Posted September 11, 2008 Share Posted September 11, 2008 thers is no direct comman di am aware of, but i ususaly do this. double click the second mtext so it will open in mtext editor. there, selct the taxt with mouce & ctrl+c. than clase the editor. now click on the first mtext, open it in editor & paste & clcik ok. than delete the second metext object Quote Link to comment Share on other sites More sharing options...
