to get my @ symbol I have to press " (shift 2), I only get the ' symbol if I press the marked key. It was OK, any ideas what has happened? I checked the windows keyboard language and even tried swopping from English British, to USA.
That problem used to happen when I had my kekbaord set up for USA.It should happen when you are using the english setting.That is weird,where did you reset the language?
I set language in Windows, You've just made me think, do I set it in AutoCad, I'll look next time I'm on.
Thanks, I had changed it in Windows but apparantley I needed to reboot before it took effect, as when I went in this morning all's OK
Nice!Its good when its something that simple. :)
  • 4 years later...
Excellent result!
I get confused (memory lapse) on my laptop when using alt + keys for symbols.
I usually forget to set the number lock key on for symbols for using alt + keys; i.e.: alt+248 = ° (degree), alt+0216 = Ø (diameter), alt+0177 = ± (plus or minus), etc.
Gettin' old, 62, I guess. :glare:
