ankers Posted November 20, 2008 Posted November 20, 2008 any ideas on how i can rotate the text in the attached drawing so that it is horizontal. cheers Drawing7.dwg Quote
Commandobill Posted November 20, 2008 Posted November 20, 2008 dimstyle go in and currently under text you have it set to be aligned with the dimension you can change it to be horizontal Quote
Tankman Posted November 20, 2008 Posted November 20, 2008 dimstyle Go in and currently under text you have it set to be aligned with the dimension you can change it to be horizontal. Painless! "Ask and you shall receive." Quote
happyunited Posted November 25, 2008 Posted November 25, 2008 Following on from this dims question I thought I would post here instead of opening a new thread. Anyone got any idea how I force the arrow heads inside the dimension here and not have them outside the way it defaults? Attached dwg. Cheers Drawing2.dwg Quote
BOB'27T Posted November 25, 2008 Posted November 25, 2008 I set the text offset to .025 and it moved them inside. Quote
Commandobill Posted November 25, 2008 Posted November 25, 2008 Even if you set it to .5 it will put the arrows inside Quote
