Hi all:
Can someone give me a lisp which can:
1.calculate each area of region or polyline seleled by user and write the area in text .
2.calculate the sum of all areas and write in text.
3.export each to Excel.
Actually I found the function 「Area Calcutaion」of CadTools almost met my need, but it only works for polylines not for regions...
Much appreciate~
Li
Thanks...
but the code cannot work for region, neither can it export the notation to Excel...
here's an update, works now for region, circle,ellipse and and closed spline
;;; CADALYST 07/08  www.cadalyst.com/code
;;; Tip 2292: AreaRon.lsp	Area of Closed Polylines	(c) 2008 Ronald Maneja (Wizman)
;;; PRODUCES TEXT CONTAINING AREA OF  SELECTED CLOSED POLYLINES
;;; AND PUTS THEM IN AREARON LAYER
;;; CREATED BY RON MANEJA 31JAN08
;;; USER INPUTS: SCALE, POLYLINE SELECTION
;;; VERSION 1.1 (09FEB09): ADDED AREA FOR REGIONS, SPLINE, CIRCLE & ELLIPSE
(defun C:AREARON (/
	  allx
	  ally
	  areaobj
	  counter
	  ctr
	  el
	  entity-name
	  entnamevla
	  mysset
	  prec_temp
	  pt
	  reg_centroid
	  temp
	  tst
	  vertex
	  x
	  y
	  oldlayer
	  oldsnap
	  temperr
	  traperror
	  blpt
	  cir_center
	  el_center
	  maxpt
	  minpt
	  spl_center
	  trpt
(defun set_var ()
 (setvar 'cmdecho 0)
 (setq oldlayer (getvar "clayer"))
 (setq oldsnap (getvar "osmode"))
 (setq temperr *error*)
 (setq *error* traperror)
 (setvar "osmode" 0)
(defun traperror (errmsg)
 (command nil nil nil)
 (if (not (member errmsg '("console break" "Function Cancelled"))
   (princ (strcat "\nError: " errmsg))
 (command "_.undo" "end")
 (setvar "clayer" oldlayer)
 (setvar "osmode" oldsnap)
 (setvar "cmdecho" 1)
 (princ "\nError Resetting Enviroment ")
 (setq *error* temperr)
(defun reset_var ()
 (vl-load-com)
 (set_var)
 (command "_.undo" "be")
 (if (tblsearch "Layer" "AREARON")
   (command "._layer" "_thaw" "AREARON" "_on" "AREARON" "_unlock" "AREARON" "_set" "AREARON" "") ;_ closes command
   (command "._layer" "_make" "AREARON" "_color" 1 "AREARON" "") ;_ closes command
 (if (null sch)
   (setq sch 1.0)
 (initget 6)
 (setq	temp (getreal (strcat "\nENTER SCALE <"
		      (rtos sch 2 2)
 (if temp
   (setq sch temp)
   (setq temp sch)
 (if (null precision)
   (setq precision 1)
 (initget 6)
 (setq	prec_temp
 (getint
   (strcat "\nHOW MANY DECIMAL PLACES?: <"
	   (rtos precision 2 2)
 (if prec_temp
   (setq precision prec_temp)
   (setq prec_temp precision)
 (prompt "\nSELECT CLOSED POLYLINES/SPLINES, REGION, CIRCLE & ELLIPSE:> ")
 (setq
   mysset  (ssget '((-4 . "<or")
	     (-4 . "<and")
	     (0 . "LWPOLYLINE")
	     (70 . 1)
	     (-4 . "and>")
	     (-4 . "<and")
	     (0 . "SPLINE")
	     (70 . 11)
	     (-4 . "and>")
	     (0 . "REGION")
	     (0 . "CIRCLE")
	     (0 . "ELLIPSE")
	     (-4 . "or>")
   counter 0
 (if mysset
     (while (< counter (sslength mysset))
(setq entity-name (ssname mysset counter)
      EL	  (entget entity-name)
      entnamevla  (vlax-ename->vla-object entity-name)
      areaobj	  (vla-get-area entnamevla)
(cond
  ((eq (cdr (assoc 0 el)) "LWPOLYLINE")
     (setq allx	0
	   ally	0
	   ctr 0
	   tst 1
     (while (assoc 10 el)
       (setq vertex (cdr (assoc 10 el))
	     ctr    (+ ctr 1)
	     x	    (car vertex)
	     y	    (cadr vertex)
	     allx   (+ allx x)
	     ally   (+ ally y)
	     EL	    (cdr (member (assoc 10 el) el))
     (setq x  (/ allx ctr)
	   y  (/ ally ctr)
	   pt (list x y)
     (command "text"
	      "j"
	      "mc"
	      pt
	      (* sch 2.5)
	      "0"
	      (rtos areaobj 2 precision)
  ((eq (cdr (assoc 0 el)) "REGION")
   (setq reg_centroid
	  (vlax-safearray->list
	    (vlax-variant-value
	      (vla-get-centroid entnamevla)
   (command "text"
	    "j"
	    "mc"
	    reg_centroid
	    (* sch 2.5)
	    "0"
  ((eq (cdr (assoc 0 el)) "CIRCLE")
   (setq cir_center
	    (vlax-variant-value
	      (vla-get-center entnamevla)
   (command "text"
	    "j"
	    "mc"
	    cir_center
	    (* sch 2.5)
	    "0"
  ((eq (cdr (assoc 0 el)) "ELLIPSE")
   (setq el_center
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    el_center
	    (* sch 2.5)
	    "0"
  ((eq (cdr (assoc 0 el)) "SPLINE")
   (vla-GetBoundingBox entnamevla 'minPt 'maxPt)
   (setq blPt (vlax-safearray->list minPt)
	 trPt (vlax-safearray->list maxPt)
   (setq spl_center
	  (mapcar '* '(0.5 0.5 0.5) (mapcar '+ blPt trPt))
   (command "text"
	    "j"
	    "mc"
	    spl_center
	    (* sch 2.5)
	    "0"
(setq counter (+ counter 1))
   (alert "\nNO CLOSED POLYLINES/LWPOLYLINES/SPLINES IN YOUR SELECTION"
 (reset_var)
(prompt "'\n>>>...AreaRon.Lsp is now Loaded, Type 'Arearon' to start command...<<<")
it does not yet exports to excel, i'll try to add it when i have a free time.
  • 16 years later...
(defun C:AREARON (/
	  allx
	  ally
	  areaobj
	  counter
	  ctr
	  el
	  entity-name
	  entnamevla
	  mysset
	  prec_temp
	  pt
	  reg_centroid
	  temp
	  tst
	  vertex
	  x
	  y
	  oldlayer
	  oldsnap
	  temperr
	  traperror
	  blpt
	  cir_center
	  el_center
	  maxpt
	  minpt
	  spl_center
	  trpt
(defun set_var ()
 (setvar 'cmdecho 0)
 (setvar "osmode" 0)
(defun reset_var ()
 (vl-load-com)
 (set_var)
 (if (null sch)
   (setq sch 1.0)
 (initget 6)
		      (rtos sch 2 2)
 (if temp
   (setq sch temp)
   (setq temp sch)
   (setq precision 1)
 (initget 6)
 (setq	prec_temp
 (getint
 (if prec_temp
 (setq
	     (-4 . "<and")
	     (0 . "LWPOLYLINE")
	     (70 . 1)
	     (-4 . "and>")
	     (-4 . "<and")
	     (0 . "SPLINE")
	     (70 . 11)
	     (-4 . "and>")
	     (0 . "REGION")
	     (0 . "CIRCLE")
	     (0 . "ELLIPSE")
	     (-4 . "or>")
   counter 0
 (if mysset
(cond
     (setq allx	0
	   ally	0
	   ctr 0
	   tst 1
	     ctr    (+ ctr 1)
	     x	    (car vertex)
	     y	    (cadr vertex)
	     allx   (+ allx x)
	     ally   (+ ally y)
	   y  (/ ally ctr)
	   pt (list x y)
     (command "text"
	      "j"
	      "mc"
	      pt
	      (* sch 2.5)
	      "0"
   (setq reg_centroid
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    reg_centroid
	    (* sch 2.5)
	    "0"
   (setq cir_center
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    cir_center
	    (* sch 2.5)
	    "0"
   (setq el_center
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    el_center
	    (* sch 2.5)
	    "0"
   (setq spl_center
   (command "text"
	    "j"
	    "mc"
	    spl_center
	    (* sch 2.5)
	    "0"
 (reset_var)
Bro can help me change unit mm2 -> m2
Just have to insert a line
(defun C:AREARON (/
	  allx
	  ally
	  areaobj
	  counter
	  ctr
	  el
	  entity-name
	  entnamevla
	  mysset
	  prec_temp
	  pt
	  reg_centroid
	  temp
	  tst
	  vertex
	  x
	  y
	  oldlayer
	  oldsnap
	  temperr
	  traperror
	  blpt
	  cir_center
	  el_center
	  maxpt
	  minpt
	  spl_center
	  trpt
(defun set_var ()
 (setvar 'cmdecho 0)
 (setvar "osmode" 0)
(defun reset_var ()
 (vl-load-com)
 (set_var)
 (if (null sch)
   (setq sch 1.0)
 (initget 6)
		      (rtos sch 2 2)
 (if temp
   (setq sch temp)
   (setq temp sch)
   (setq precision 1)
 (initget 6)
 (setq	prec_temp
 (getint
 (if prec_temp
 (setq
	     (-4 . "<and")
	     (0 . "LWPOLYLINE")
	     (70 . 1)
	     (-4 . "and>")
	     (-4 . "<and")
	     (0 . "SPLINE")
	     (70 . 11)
	     (-4 . "and>")
	     (0 . "REGION")
	     (0 . "CIRCLE")
	     (0 . "ELLIPSE")
	     (-4 . "or>")
   counter 0
 (if mysset
      areaobj	  (/ areaobj 1000000.)		;;; This line makes mm2 -> m2
(cond
     (setq allx	0
	   ally	0
	   ctr 0
	   tst 1
	     ctr    (+ ctr 1)
	     x	    (car vertex)
	     y	    (cadr vertex)
	     allx   (+ allx x)
	     ally   (+ ally y)
	   y  (/ ally ctr)
	   pt (list x y)
     (command "text"
	      "j"
	      "mc"
	      pt
	      (* sch 2.5)
	      "0"
   (setq reg_centroid
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    reg_centroid
	    (* sch 2.5)
	    "0"
   (setq cir_center
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    cir_center
	    (* sch 2.5)
	    "0"
   (setq el_center
	    (vlax-variant-value
   (command "text"
	    "j"
	    "mc"
	    el_center
	    (* sch 2.5)
	    "0"
   (setq spl_center
   (command "text"
	    "j"
	    "mc"
	    spl_center
	    (* sch 2.5)
	    "0"
 (reset_var)
