Small Fish Posted November 4, 2009 Posted November 4, 2009 Hi probably an easy one..... When I use the command mtext in my code for example: (command "Mtext" pt1 "_Justify" TL "HEIGHT" #TxtHgt pt3) I always get this annoying returned message in the command line. How can I not show this: Current text style: "STANDARD" Text height: 55.0000 Cmdecho is set to 0 thanks Quote
Freerefill Posted November 4, 2009 Posted November 4, 2009 The only two tricks I use to get rid of prompts like that is setting cmdecho to 0 and/or nomutt to 1. Neither seemed to work. I did have the same issue before with MText and I couldn't get rid of that prompt. It might be that you simply cannot. Quote
jalucerol Posted November 5, 2009 Posted November 5, 2009 sure there is'nt a system variable to enable or disable the mtext behaviour? Quote
alanjt Posted November 5, 2009 Posted November 5, 2009 It can only be suppressed by changing the nomutt system variable. Quote
alanjt Posted November 5, 2009 Posted November 5, 2009 You can use this: http://www.cadtutor.net/forum/showpost.php?p=278945&postcount=40 Quote
Small Fish Posted November 6, 2009 Author Posted November 6, 2009 Thanks Alan - yes that is good. I am just curious about what the 'AT' means in (defun AT: ??? Quote
alanjt Posted November 6, 2009 Posted November 6, 2009 Thanks Alan - yes that is good. I am just curious about what the 'AT' means in (defun AT: ??? Just a nice alternative to worrying with the command. I prefix subroutines I write with AT: to stay organized. Plus I can filter them out if needed easier from (atoms-family 1). AT: = Alan Thompson You can also do (vla-put-rotation (AT:MText......) radians). Quote
