Drock Posted February 10, 2010 Share Posted February 10, 2010 I need to despeckle and the program tells me that the command is only usable for a bitonal image. How do I change my raster to a bitonal image? Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 10, 2010 Share Posted February 10, 2010 Bitonal means a 1 bit image, every pixel is either present (black) or not (white) - so the results of this conversion may not be what you like... To do the conversion, run the ._IDEPTH command in Raster Design. Quote Link to comment Share on other sites More sharing options...
ccook79 Posted August 20, 2010 Share Posted August 20, 2010 Bitonal means a 1 bit image, every pixel is either present (black) or not (white) - so the results of this conversion may not be what you like... To do the conversion, run the ._IDEPTH command in Raster Design. I tried to run the ._IDEPTH command in raster design and it comes up with the following error "The image or images that you are trying to edit cannot be edited" My main goal here is to embed the image so that i can send out...command line says it embeds but doesnt show up when sent out Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted August 20, 2010 Share Posted August 20, 2010 ...command line says it embeds but doesnt show up when sent out I'm pretty sure the person opening the drawing on the other end will need Raster Design or the Raster Design OE installed. Quote Link to comment Share on other sites More sharing options...
