CJJ Posted June 28, 2010 Posted June 28, 2010 I have had two of our company's AutoCAD users report a similar message. Both of them seem to have gotten this on Friday, and every time they open AutoCAD this happens. The message pops up showing an error, and when you click Continue, everything seems to be working. I've googled the message, and couldn't find much information that applies to AutoCAD. I think the "URI" message means there is a problem in Mircosoft .NET Framework, but that's about all I can get from it. I was just wondering if anyone had seen a similar message, or has any idea how to fix the problem. I apologize for the long post, but I'm going to paste the full details of the error messages. Unhandled Exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue. Invalid URI: The format of the URI could not be determined. One is using Civil 3D 2009, and gets the following under details: Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.UriFormatException: Invalid URI: The URI scheme is not valid. at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind) at System.Uri..ctor(String uriString) at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel) at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents) at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter() at Autodesk.InfoCenter.PaletteMgr.get_CommCntrSrc() at Autodesk.InfoCenter.PaletteMgr.LoadCommCenterSources() at Autodesk.InfoCenter.PaletteMgr.InitCommCenter() at Autodesk.InfoCenter.PaletteMgr.InitSources() at Autodesk.InfoCenter.PaletteMgr.FirstInvoke() at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e) at System.Windows.Forms.Application.RaiseIdle(EventArgs e) at Autodesk.AutoCAD.ApplicationServices.Application.OnIdleWinForms() at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3603 (GDR.050727-3600) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- acdbmgd Assembly Version: 17.2.0.0 Win32 Version: 17.2.711.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcdbMgd.DLL ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- msvcm80 Assembly Version: 8.0.50727.3053 Win32 Version: 8.00.50727.3053 CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- PresentationFramework Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1500 built by: QFE CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- acmgd Assembly Version: 17.2.0.0 Win32 Version: 17.2.711.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/acmgd.DLL ---------------------------------------- AdWindowsWrapper Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdWindowsWrapper.DLL ---------------------------------------- AdWindows Assembly Version: 1.0.0.0 Win32 Version: 1.0.711.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdWindows.DLL ---------------------------------------- ResourceManagement Assembly Version: 12.0.76.0 Win32 Version: 12.0.076.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/ResourceManagement.DLL ---------------------------------------- AdWindows.resources Assembly Version: 1.0.0.0 Win32 Version: 1.0.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/en-US/AdWindows.resources.DLL ---------------------------------------- PresentationFramework.Classic Assembly Version: 3.0.0.0 Win32 Version: 3.0.6920.1427 built by: SP CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/PresentationFramework.Classic/3.0.0.0__31bf3856ad364e35/PresentationFramework.Classic.dll ---------------------------------------- AcMgdReverse Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcMgdReverse.DLL ---------------------------------------- Redland.NET Assembly Version: 1.0.2.1 Win32 Version: 1.0.2.1 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/Redland.NET.DLL ---------------------------------------- AcInfoCenterConn Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcInfoCenterConn.DLL ---------------------------------------- AdInfoCenter Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AdInfoCenter.DLL ---------------------------------------- AcWindows Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/AcWindows.DLL ---------------------------------------- AdInfoCenter.resources Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/en-US/AdInfoCenter.resources.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Web.Services Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll ---------------------------------------- Autodesk.Interop.WSCommCntr1 Assembly Version: 17.2.0.0 Win32 Version: 17.2.56.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%202009/Autodesk.Interop.WSCommCntr1.DLL ---------------------------------------- Microsoft.JScript Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.JScript/8.0.0.0__b03f5f7f11d50a3a/Microsoft.JScript.dll ---------------------------------------- ************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information. Quote
CJJ Posted June 28, 2010 Author Posted June 28, 2010 The second user is using Map 3D 2009, and this is what the details shows See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.UriFormatException: Invalid URI: The format of the URI could not be determined. at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind) at System.Uri..ctor(String uriString) at Autodesk.InfoCenter.CommunicationCenter.PopulateContents(ResultItemCollection& contentCollection, ICommCntrChannel channel) at Autodesk.InfoCenter.CommunicationCenter.GetContents(ResultItemCollection& channelContents) at Autodesk.InfoCenter.CommCntrSource.InitCommunicationCenter() at Autodesk.InfoCenter.PaletteMgr.InitCommCenter() at Autodesk.InfoCenter.PaletteMgr.InitPalettes() at Autodesk.InfoCenter.PaletteMgr.FirstInvoke() at Autodesk.InfoCenter.PaletteMgr.OnAppIdle(Object sender, EventArgs e) at System.Windows.Forms.Application.RaiseIdle(EventArgs e) at ?A0x2b7cf235.OnIdle() ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3603 (GDR.050727-3600) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- acdbmgd Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcdbMgd.DLL ---------------------------------------- ResourceManagement Assembly Version: 11.0.79.0 Win32 Version: 11.0.079.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/ResourceManagement.DLL ---------------------------------------- msvcm80 Assembly Version: 8.0.50727.3053 Win32 Version: 8.00.50727.3053 CodeBase: file:///C:/WINDOWS/WinSxS/x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca/msvcm80.dll ---------------------------------------- acmgd Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/acmgd.DLL ---------------------------------------- AecDtlDb Assembly Version: 5.5.256.0 Win32 Version: 5, 5, 256, 0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDb.DLL ---------------------------------------- AecDtlDbUI Assembly Version: 5.5.256.0 Win32 Version: 5.5.256.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbUI.DLL ---------------------------------------- AecDtlDbLib Assembly Version: 5.5.256.0 Win32 Version: 5.5.256.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AecDtlDbLib.DLL ---------------------------------------- Redland.NET Assembly Version: 1.0.2.1 Win32 Version: 1.0.2.1 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Redland.NET.DLL ---------------------------------------- AcInfoCenterConn Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AcInfoCenterConn.DLL ---------------------------------------- AdInfoCenter Assembly Version: 17.1.0.0 Win32 Version: 17.1.219.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/AdInfoCenter.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- Autodesk.Interop.AcInetEngine Assembly Version: 17.1.51.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.AcInetEngine.DLL ---------------------------------------- AdInfoCenter.resources Assembly Version: 17.1.0.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/en-US/AdInfoCenter.resources.DLL ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- ii5ogyiu Assembly Version: 17.1.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- Autodesk.Interop.WSCommCntr1 Assembly Version: 17.1.51.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WSCommCntr1.DLL ---------------------------------------- Autodesk.Interop.WebServices1 Assembly Version: 17.1.51.0 Win32 Version: 17.1.51.0 CodeBase: file:///C:/Program%20Files/AutoCAD%20Civil%203D%20Land%20Desktop%20Companion%202008/Autodesk.Interop.WebServices1.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT de****** registered on the computer rather than be handled by this dialog box. Quote
mela2010 Posted July 1, 2010 Posted July 1, 2010 Hi No solution to this URI problem, but I have 8 users in one of our locations in Finland who just now reported this incident. I am also googling around for help. These users have AutoCad 2008 LT Quote
mela2010 Posted July 1, 2010 Posted July 1, 2010 I noticed that on the 28.6 I have received following updates: Microsoft NET Framework 2 Service Pack 2 - KB976576 Microsoft NET Framework 2 Service Pack 3 - KB977354 I asked our designers having the problem to remove updates and see if that helps Quote
mela2010 Posted July 1, 2010 Posted July 1, 2010 it wasn't that easy - still looking for a solution Quote
zapper Posted July 2, 2010 Posted July 2, 2010 My AutoCAD Lt 2009 was working fine this morning, installed the latest i-tunes 9.2 (64bit) then started getting the URI error. Will try and uninstall that to see if it works, but cant imagine why i-tunes will affect autocad. EDIT - Uninstalled i-tunes and the URI error has gone and my autocad is working normally. Strange. Quote
copenkagan Posted July 26, 2010 Posted July 26, 2010 I have just started encountering this error as well. Although none of my system settings have changed. No programs or updates were installed either. I am using Civil 3D Land Desktop Companion 2008, so I'm guessing by this thread that it's not limited to one certain deployment. Quote
ajamescad Posted August 2, 2010 Posted August 2, 2010 HiNo solution to this URI problem, but I have 8 users in one of our locations in Finland who just now reported this incident. I am also googling around for help. These users have AutoCad 2008 LT I am using AutoCAD 2008 LT & have started receiving the same error. Any resolution yet? Thank you. Quote
CJJ Posted August 3, 2010 Author Posted August 3, 2010 Just had another user get this URI error yesterday, this time with AutoCAD Map 3D 2008. Still no ideas about where it comes from/how to fix it. However, the good news is that the Civil 3D '09 user's message has gone away (on its own). I don't know what changed on his system, but it's possible that a patch from Microsoft may have had something to do with it, but I don't know. Quote
drewprusso Posted August 5, 2010 Posted August 5, 2010 Myself and one other user received this error today as well. We are both running AutoCAD 2008. I am running 2010 concurrently and it have not had the error. The other guy who had the issue stated that he saw his machine performing a windows update when he booted up this morning. Quote
Maverik Posted August 6, 2010 Posted August 6, 2010 I am getting this error each and every time I open AutoCAD. No problems to report once 'Ignore' is clicked, seems more like a hinderance than anything important. Still, would be nice to be rid of it. Quote
CJJ Posted August 6, 2010 Author Posted August 6, 2010 Myself and one other user received this error today as well. We are both running AutoCAD 2008. I am running 2010 concurrently and it have not had the error. The other guy who had the issue stated that he saw his machine performing a windows update when he booted up this morning. Any idea what MS update it was? Quote
nukecad Posted August 6, 2010 Posted August 6, 2010 It will have been this security update. http://www.microsoft.com/security/updates/bulletins/ It has caused a few niggles with IE8 as well. Quote
Cadister Posted August 16, 2010 Posted August 16, 2010 Has anyone yet found solution to this problem? I have LT 2008 and started to think about that I also installed i-Tunes at the time this error started out appearing last spring. Wonder if there is more of us new apple customers? Quote
NewVillage Posted August 17, 2010 Posted August 17, 2010 I also came across this problem. Except, I am using 2008 and my dialog said "Invalid URI: The URI scheme is not valid." Google didn't return anything useful. The way I fixed it was by looking at the Exception Text. The lines that say 'Autodesk.InfoCenter' were the giveaway. That gave me a hint that it might be something called InfoCenter. I realize that turning InfoCenter off may not be an option for some -- it was for me. Googling revealed: http://otb.manusoft.com/2007/09/autocad-2008-slow-startup-fix.htm The site showed how to turn off InfoCenter via the registry key HKLM\Software\Autodesk\R17.1\[ACAD-XXXX:XXX]\Applications\InfoCenterAcConn Under that key, I changed LOADCTRLS from 76 to 0. Viola! Other links that may help: http://otb.manusoft.com/2009/03/disable-infocenter-in-autocad-2010.htm http://www.blog.cadnauseam.com/2009/04/03/autocad-2010-turning-off-infocenter/ http://www.google.com/search?hl=en&client=firefox-a&hs=DhN&rls=org.mozilla%3Aen-US%3Aofficial&q=%22turn+off%22+Autodesk+%2BInfoCenter&aq=f&aqi=&aql=&oq=&gs_rfai= HTH, Chris Quote
Erik1974 Posted August 17, 2010 Posted August 17, 2010 I too would like to know how to really fix this, surely i can also disable the infocenter but i don't think that is the real solution to this problem. What is causing it in the first place? Seeing that so many people suddenly have this "problem" would suggest a buggy MS update. Quote
Cadister Posted August 18, 2010 Posted August 18, 2010 Thanks newvillage for this solution, at least I can get rid of the error message. About being buggy update from M$, maybe so, but it has happened that they corrected something that should have been that way in the first place and someone at autodesk should wake up and make a fix accordingly. As it kind of suggest at the last lines: "Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information." I wonder why it is not proposing to send error message to autodesk as usual when something odd happens. Quote
poidog Posted August 27, 2010 Posted August 27, 2010 (edited) i'm running 2008 and have never had a problem until this morning. according to CAD people... Update for Case #3542 - "JIT DEBUG Error" Uninstall all versions of Microsoft .NET Framework from your system. Next you will want to uninstall AutoCAD 2008 from your system following these directions 1. Download and install the free version of Revo Uninstaller from the link below. http://www.revouninstaller.com/revo_uninstaller_free_download.html 2. When you have finished installing the Revo Uninstaller run the Uninstaller on your AutoCAD 2008 install and make sure to use the advanced setting when uninstalling. 3. Now install Microsoft .NET Framework 3.5 from this link http://www.microsoft.com/downloads/details.aspx?FamilyID=ab99342f-5d1a-413d-8319-81da479ab0d7&displaylang=en 4. After uninstalling reinstall your AutoCAD 2008 software but when you do make sure you are logged in as the Administrator, no other programs are running and disable your antivirus during the install. 5. After uninstalling make sure you download latest update (Update 1) from the link below http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10035892&linkID=9240618 Edited August 28, 2010 by Cad64 Edited content Quote
poidog Posted August 28, 2010 Posted August 28, 2010 i'm having the same problem. our CAD tech support sent me info to correct and i'm trying to post the solution... come on moderator, get it together. Quote
Cad64 Posted August 28, 2010 Posted August 28, 2010 come on moderator, get it together. Um, ok, please read the restrictions regarding your membership: http://www.cadtutor.net/forum/showthread.php?9177-Why-should-I-register. And pay special attention to item number 4, under the "Forum Newbies" section at the bottom of the page, as it pertains to the exact thing you are currently complaining about. And also, please understand that we do not work for you. We do not get paid to be here and we do not have to put up with attitude. So if you decide to go ahead and break the rules of the forum by putting links into your reply, then you will just have to wait until one of us notices that your post has been caught by the forum software and needs to be approved. Yelling at us and demanding that we approve your post is not the right way to get things done. What you should have done was post a follow up reply, politely asking us to check your previous post for approval. Have you ever heard the saying "You can attract more bees with honey than vinegar"? I have approved your first post, but I have left your second post in permanent moderation. You know, the one with all the capital letters and exclamation points. Hopefully that is "together" enough for you? Have a great day. :wink: Quote
