Slaraffenmann Posted September 6, 2010 Posted September 6, 2010 Does anyone know if there is a command for changing an objects layer? I want to click on an object and type "command"_"name of destination layer", or something like that... The layer manager is ok, but as long as I know the name of the destination layer, it would be quicker to change the layer by a command. Quote
migs Posted September 6, 2010 Posted September 6, 2010 do you mean? CHPROP > select objects > LA (layer) > enter layer name Quote
Slaraffenmann Posted September 6, 2010 Author Posted September 6, 2010 Ah! Something like that.. :-) Thank you.. Quote
Cat Posted September 6, 2010 Posted September 6, 2010 If you have a lot to change, it would be faster to change one to the desired layer and then use the "match properties" tool for the rest, assuming Map 3D has that command. Quote
rkent Posted September 6, 2010 Posted September 6, 2010 Select an object, or objects, then using the layer dropdown pick the layer you want those to reside on. Quote
Slaraffenmann Posted September 7, 2010 Author Posted September 7, 2010 I know about the dropdown, and i usually use that methode. But sometimes it would be better to use a command. Quote
