drewcruise Posted September 25, 2010 Posted September 25, 2010 When you insert the drawing title it always post a scale of 1 to 1 is there a way to have this automatically adjust to whatever view port you put it in?? Quote
drewcruise Posted September 27, 2010 Author Posted September 27, 2010 ok so when you drag the "drawing title-metric" block from the annotation tab of your toolbar pallet is there a way to have it automatically fill in the correct scale or is this something you must do manually each time. Quote
ReMark Posted September 27, 2010 Posted September 27, 2010 If you are inserting the title block into a layout then the default of 1:1 will always be correct. After all, your viewports can be assigned any scale but when you print you do so from your layout at a scale of 1:1. Quote
