Viktorik Posted March 22, 2011 Posted March 22, 2011 I drowed a sketch, 1 spline (curved) 3 lines, extruded it, an how I can change the points of spline from sketch with canges for solid form directly? thanks Quote
JD Mather Posted March 22, 2011 Posted March 22, 2011 Edit the sketch. There is an example in this tutorial http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%202011%20Tutorial%2014.pdf and this one http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%206.pdf Quote
Viktorik Posted March 23, 2011 Author Posted March 23, 2011 the problem was that in Inventor Fusion, I edited the cketch but the solid does not apply transformations, Now with inventor professional it works... Is it true that all what I do in Autocad Architecture i can do with Inventor? always ai attache a jpg i draw lines and polylines on image, extrude them , subtract, union , ant some parameters... where to find ploting settings, plot scale, style - for export to pdf, or jpg 3d hidden,lines... ? Quote
JD Mather Posted March 23, 2011 Posted March 23, 2011 Inventor Fusion very different from Inventor. In Inventor a part is an ipt file, an assembly is an iam file and a drawing is an idw or dwg file (similar to the real world). Go through the built in Help>Learning Tools>Tutorials and Skillbuilders. Quote
