I am currently using AutoCAD 2011 and have an issue and looking for assistance. when I create a template, and start demensioning, the font size are always set to the default (.2) is there a setting to choose to make the font size relative to the size of dwg so that I do not have to increase the size of the fonts each time I do a dimension or any text.? thanks
Just type dimscale and increase the value as best as you want . :)
Tharwat
Are you drawing 1:1 in Model Space?
type "D" and this will bring out dimension style manager, select modify and this will bring out the modify dimension style, go to text and set the height to your convenience.
