woodman78 Posted May 16, 2011 Share Posted May 16, 2011 I am trying to change block visibility by lisp and have cobbled this together. It doesn't work though and I was wondering if someone could have a look for me. Thanks. (defun c:Legend_Scale (/ LName BWild obj) (setq LName "dyn_legend") ;Get the layer's name (setq BWild (strcat "*" LName "*")) ;Default to LName (setq obj (ssget "_X" (list '(0 . "INSERT") (cons 2 BWild)))) ;And some blocks found (chgdynprop obj "visibility" "1:1000") (entupd obj) (princ) ) (defun chgdynprop (e propname newval / obj v vval sal tot i) (setq obj (if (= (type e) 'vla-object) e (vlax-ename->vla-object e))) (if (= (vlax-get-property obj 'isdynamicblock) :vlax-true) (progn (setq v (vla-getdynamicblockproperties obj) vval (vlax-variant-value v) sal (vlax-safearray->list vval) tot (length sal) i 0 );setq (while (< i tot) (if (= (vlax-get-property (nth i sal) "PropertyName") propname) (progn (vlax-put-property (nth i sal) "Value" newval) (setq i tot) );progn (setq i (1+ i)) );endif );endwhile );progn );endif );chgdynprop Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 16, 2011 Share Posted May 16, 2011 (edited) Give this a try: (defun c:FOO ( / ss dynProps val) (vl-load-com) (if (setq ss (ssget "_x" '((0 . "INSERT") ([color=blue]2[/color] . "[color=blue]*[/color]DYN_LEGEND[color=blue]*[/color]")))) (progn (vla-startundomark (cond (*activeDoc*) ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))) (vlax-for x (setq ss (vla-get-activeselectionset *activeDoc*)) (if (and (= :vlax-true (vla-get-isdynamicblock x)) (vl-string-search "DYN_LEGEND" (strcase (vla-get-effectivename x))) (setq dynProps (car (vlax-invoke x 'getdynamicblockproperties))) (vl-position (cond (val) ((setq val "1:1000"))) (vlax-get dynProps 'allowedvalues))) (vlax-put-property dynProps 'value val))) (vla-endundomark *activeDoc*) (vla-delete ss)) (prompt "\n** Nothing selected ** ")) (princ)) Note that if val ("1:1000") is not included in the dynamic block's AllowedValues, no action is taken. Edited May 17, 2011 by BlackBox Code revised Quote Link to comment Share on other sites More sharing options...
woodman78 Posted May 17, 2011 Author Share Posted May 17, 2011 Thanks RenderMan. I keep getting "nothing selected" though. I have tried renaming blocks and different things but no joy. Any ideas? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 17, 2011 Share Posted May 17, 2011 This ... (8 . "DYN_LEGEND") (2 . "DYN_LEGEND") Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 17, 2011 Share Posted May 17, 2011 Thanks RenderMan. I keep getting "nothing selected" though. I have tried renaming blocks and different things but no joy. Any ideas? That means you have no blocks on the "DYN_LEGEND" layer. Perhaps I misinterpreted your original code... I took this line: (defun c:Legend_Scale (/ LName BWild obj) (setq LName "dyn_legend") ;Get the layer's name ... To mean that would be the block's layer name? Thus, I included this: (if (setq ss (ssget "_x" '((0 . "INSERT") ([color=red]8 . "DYN_LEGEND"[/color])))) ... Where DXF code 8 is the entity's layer name. Try replacing the code in red with this: (2 . "*DYN_LEGEND*") ... Otherwise, we'll just step through an SS of all blocks. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted May 17, 2011 Share Posted May 17, 2011 (2 . "*DYN_LEGEND*") Don't forget to add the asterisks. :wink: Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 17, 2011 Share Posted May 17, 2011 Don't forget to add the asterisks. :wink: Of course. Regards. Quote Link to comment Share on other sites More sharing options...
lamensterms Posted March 4, 2013 Share Posted March 4, 2013 Hey guys, I’m just discovering these visibility states of dynamic blocks myself, pretty interesting and could be very useful. I’m just in the process of customizing a clients drawing sheet for use in our office and and just trying to understand how I can batch toggle the visibility state of a block in multiple drawings. The routine above looks like it should do the trick – but unfortunately when I run it – the result is “** Nothing selected **”. If I remove the block name filter from the selection set, the routine seems to run fine. My working code is… (defun c:test1 ( / ss dynProps val) (vl-load-com) (if (setq ss (ssget "_x" '((0 . "INSERT")))) (progn (vla-startundomark (cond (*activeDoc*) ((setq *activeDoc* (vla-get-activedocument (vlax-get-acad-object)))))) (vlax-for x (setq ss (vla-get-activeselectionset *activeDoc*)) (if (and (= :vlax-true (vla-get-isdynamicblock x)) (vl-string-search "4057_STICKER" (strcase (vla-get-effectivename x))) (setq dynProps (car (vlax-invoke x 'getdynamicblockproperties))) (vl-position (cond (val) ((setq val "For Client Review"))) (vlax-get dynProps 'allowedvalues))) (vlax-put-property dynProps 'value val))) (vla-endundomark *activeDoc*) (vla-delete ss)) (prompt "\n** Nothing selected ** ")) (princ)) But I cannot understand why it doesn’t detect my block named "4057_STICKER". Does it have anything to do with the Anonymous Name? Thanks for all your help. Quote Link to comment Share on other sites More sharing options...
