Hi i want to have a lisp that will freeze layer batters in the drawing batters but i don't want it to do it any where else. even if i run the lisp
Heres what iv got so far
(setq dn (getvar 'DWGNAME))
(if (= dn "batters.dwg")
(command "-layers" "F" "BATTERS")
);if
this won't work what am i doing wrong.
(command "-layer"........... not "-layers"
The use of command is going to be slower than ent* or vla, but it's more than sufficient.
For command usage, here's what I'd do...
(if (and (eq (strcase (getvar 'DWGNAME)) "BATTERS.DWG") ;capitalize to ignore case
        (tblsearch "LAYER" "BATTERS") ;check if layer exists (not really necessary)
 (if (eq (strcase (getvar 'CLAYER)) "BATTERS") ;check if current layer is "BATTERS"
   (command "_.-layer" "_T" "0" "_S" "0" "_F" "BATTERS" "") ; if so, thaw/set 0 as current and freeze layer
   (command "_.-layer" "_F" "BATTERS" "") ; freeze layer
Codes and not command call . :D
   (setq l (entget (tblobjname "LAYER" "BATTERS")))
   (entmod (subst (cons 70 1) (assoc 70 l) l))
Tharwat
Tharwat
I hope the layer isn't locked, current, etc.
You might benefit from reading about the additional properties stored in dxf 70 for layers. :roll:
1+
Read up on the use of such functions as logand / logior / boole etc.
1+
This is two in one :lol:
   (cond ((eq (strcase (getvar 'clayer)) "BATTERS")
          (setvar 'clayer "0")
   (if (eq (logand 4 (cdr (assoc 70 l))) 4)
     (entmod (subst (cons 70 0) (assoc 70 l) l))
I give up. I'm not sure why the need was felt to over complicate this thread for a beginning LISPER in the first place.
What if the layer is frozen in new viewports? Or XRef dependent? Or indeed if any other Group 70 bit-codes are set? ;)
[ATTACH=CONFIG]30403[/ATTACH][ATTACH=CONFIG]30404[/ATTACH][ATTACH=CONFIG]30403[/ATTACH]
Were not you the first adviser for all these steps ? :rofl:
Yes and I kept it simple and as close to his coding as possible.
OMG ........ :o
To remove confusion for the OP, here is one way to approach the problem using entmod:
(defun c:test ( / e )
   (if
       (and
           (setq e (tblobjname "LAYER" "BATTERS"))
           (if (eq "BATTERS" (strcase (getvar 'CLAYER)))
               (setvar 'CLAYER "0")
           (setq e (entget e))
           (entmod (subst (cons 70 (logior 1 (cdr (assoc 70 e)))) (assoc 70 e) e))
Don't forget to account for 0 being frozen.....we're are over complicating this.
Good catch.
Solution:
(defun c:test ( / e l )
   (if
       (and
                   (setq l (entget (tblobjname "LAYER" "0")))
                   (entmod (subst (cons 70 (boole 4 1 (cdr (assoc 70 l)))) (assoc 70 l) l))
           (setq e (entget e))
But I agree - "-Layer" is far easier for this task.
Thanks guys for your help.
But if i wanted to repeat a freeze of multible layer with the condition of drawing name.
Is there a way to include an simple user interface like an excel sheet.
Sunny
P.S this is my completed code
(if (and (eq (strcase (getvar 'DWGNAME)) "GLRL-01DC-DWG-PW-GE-SMC-0202-A.DWG") ;ADD DWG NAME HERE IN CAPITALS
 (if (eq (strcase (getvar 'CLAYER)) "X_PW_GE_SMC_LS_GINT|DP_BH103") ;ADD LAYER NAME HERE IN CAPITALS
   (command "_.-layer" "_T" "0" "_S" "0" "_F" "X_PW_GE_SMC_LS_GINT|DP_BH103" "") ;ADD LAYER NAME HERE IN CAPITALS
   (command "_.-layer" "_F" "X_PW_GE_SMC_LS_GINT|DP_BH103" "") ;ADD LAYER NAME HERE IN CAPITALS
(if (and (eq (strcase (getvar 'DWGNAME)) "GLRL-01DC-DWG-PW-GE-SMC-0210-A.DWG") ;ADD DWG NAME HERE IN CAPITALS
   (command "_.-layer" "_T" "0" "_S" "0" "_F" "X_PW_GE_SMC_LS_GINT|DP_TP17" "") ;ADD LAYER NAME HERE IN CAPITALS
   (command "_.-layer" "_F" "X_PW_GE_SMC_LS_GINT|DP_TP17" "") ;ADD LAYER NAME HERE IN CAPITALS
(if (and (eq (strcase (getvar 'DWGNAME)) "GLRL-01DC-DWG-PW-GE-SMC-0215-A.DWG") ;;ADD DWG NAME HERE IN CAPITALS
 (if (eq (strcase (getvar 'CLAYER)) "X_PW_GE_SMC_LS_GINT|SB_24") ;ADD LAYER NAME HERE IN CAPITALS
   (command "_.-layer" "_T" "0" "_S" "0" "_F" "X_PW_GE_SMC_LS_GINT|SB_24" "") ;ADD LAYER NAME HERE IN CAPITALS
   (command "_.-layer" "_F" "X_PW_GE_SMC_LS_GINT|SB_24" "") ;ADD LAYER NAME HERE IN CAPITALS
and yes i relise that i am still using command call just give me a couple of day to look over you code entrys
Don't worry about using the Command call! It is more than sufficient for your purpose :)
