hatchelhoff Posted November 26, 2011 Posted November 26, 2011 The Code below selects entities in a drawing. I now need to create a new group called groupa mad up of the selected entities. What do I need to add to my code Public Class Class1 <CommandMethod("selectwindowa")> _ Public Sub selectwindowa() Dim mydb As Database = HostApplicationServices.WorkingDatabase Dim mydwg As Document = DocumentManager.MdiActiveDocument Dim myeditor As Editor = DocumentManager.MdiActiveDocument.Editor Dim myPPR As Point3d = myeditor.GetPoint("Select 1st Point: ").Value Dim myPPR1 As Point3d = myeditor.GetCorner("Select 2nd Point: ", myPPR).Value Dim mypsr As PromptSelectionResult = mydwg.Editor.SelectWindow( _ myPPR, myPPR1) If mypsr.Status = PromptStatus.OK Then Using myTrans As Transaction = mydwg.TransactionManager.StartTransaction For Each myObjectID As ObjectId In mypsr.Value.GetObjectIds Dim myEnt As Entity = myObjectID.GetObject(OpenMode.ForRead) 'Insert Code Here Next End Using End If End Sub End Class Quote
hatchelhoff Posted November 28, 2011 Author Posted November 28, 2011 I now have some code which will Create a Group but I am getting a warning message which says "Function "selectobjectsforgroup" doesnt return a value on all code paths A null reference exception could occur at run time when the result is used" I have run the code and it causes autocad to crash. What changes do I need to make here is my code thus far Public Class Class2 <CommandMethod("CG")> _ Public Sub CreateGroup() Dim mydwg As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = mydwg.Database Dim myeditor As Editor = mydwg.Editor Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr ' Get the group dictionary from the drawing Dim gd As DBDictionary = DirectCast(tr.GetObject(db.GroupDictionaryId, OpenMode.ForRead), DBDictionary) ' Check the group name, to see whether it's ' already in use Dim pso As New PromptStringOptions(vbLf & "Enter new group name: ") pso.AllowSpaces = True ' A variable for the group's name Dim grpName As String = "" Do Dim pr As PromptResult = myeditor.GetString(pso) ' Just return if the user cancelled ' (will abort the transaction as we drop out of the using ' statement's scope) If pr.Status <> PromptStatus.OK Then Return End If Try ' Validate the provided symbol table name SymbolUtilityServices.ValidateSymbolName(pr.StringResult, False) ' Only set the block name if it isn't in use If gd.Contains(pr.StringResult) Then myeditor.WriteMessage(vbLf & "A group with this name already exists.") Else grpName = pr.StringResult End If Catch ' An exception has been thrown, indicating the ' name is invalid myeditor.WriteMessage(vbLf & "Invalid group name.") End Try Loop While grpName = "" ' Create our new group... Dim grp As New Group("Test group", True) ' Add the new group to the dictionary gd.UpgradeOpen() Dim grpId As ObjectId = gd.SetAt(grpName, grp) tr.AddNewlyCreatedDBObject(grp, True) ' Open the model-space Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) Dim ms As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord) ' Add some lines to the group to form a square ' (the entities belong to the model-space) Dim ids As New ObjectIdCollection() Dim ents As DBObjectCollection = Selectobjectsforgroup(0) For Each ent As Entity In ents Dim id As ObjectId = ms.AppendEntity(ent) ids.Add(id) tr.AddNewlyCreatedDBObject(ent, True) Next grp.InsertAt(0, ids) ' Commit the transaction tr.Commit() ' Report what we've done myeditor.WriteMessage(vbLf & "Created group named ""{0}"" containing {1} entities.", grpName, ents.Count) End Using End Sub Private Function Selectobjectsforgroup(ByVal size As Double) As DBObjectCollection Dim mydwg As Document = DocumentManager.MdiActiveDocument Dim db As Database = mydwg.Database Dim myeditor As Editor = DocumentManager.MdiActiveDocument.Editor Dim myPPR As Point3d = myeditor.GetPoint("Select 1st Point: ").Value Dim myPPR1 As Point3d = myeditor.GetCorner("Select 2nd Point: ", myPPR).Value Dim mypsr As PromptSelectionResult = mydwg.Editor.SelectWindow( _ myPPR, myPPR1) If mypsr.Status = PromptStatus.OK Then Using myTrans As Transaction = mydwg.TransactionManager.StartTransaction For Each myObjectID As ObjectId In mypsr.Value.GetObjectIds Dim myEnt As Entity = myObjectID.GetObject(OpenMode.ForRead) Next End Using End If End Function End Class Quote
hatchelhoff Posted November 28, 2011 Author Posted November 28, 2011 I now have a code which comes closer to grouping my selected objects. The only problem is when I run it I get an error in autocad saying "Unhandled Exception has occured in a component in your application" How do I fix it? Public Class Class2 <CommandMethod("CG")> _ Public Sub CreateGroup() Dim mydwg As Document = Application.DocumentManager.MdiActiveDocument Dim db As Database = mydwg.Database Dim myeditor As Editor = mydwg.Editor Dim tr As Transaction = db.TransactionManager.StartTransaction() Using tr ' Get the group dictionary from the drawing Dim gd As DBDictionary = DirectCast(tr.GetObject(db.GroupDictionaryId, OpenMode.ForRead), DBDictionary) ' Check the group name, to see whether it's ' already in use Dim pso As New PromptStringOptions(vbLf & "Enter new group name: ") pso.AllowSpaces = True ' A variable for the group's name Dim grpName As String = "" Do Dim pr As PromptResult = myeditor.GetString(pso) ' Just return if the user cancelled ' (will abort the transaction as we drop out of the using ' statement's scope) If pr.Status <> PromptStatus.OK Then Return End If Try ' Validate the provided symbol table name SymbolUtilityServices.ValidateSymbolName(pr.StringResult, False) ' Only set the block name if it isn't in use If gd.Contains(pr.StringResult) Then myeditor.WriteMessage(vbLf & "A group with this name already exists.") Else grpName = pr.StringResult End If Catch ' An exception has been thrown, indicating the ' name is invalid myeditor.WriteMessage(vbLf & "Invalid group name.") End Try Loop While grpName = "" ' Create our new group... Dim grp As New Group("Test group", True) ' Add the new group to the dictionary gd.UpgradeOpen() Dim grpId As ObjectId = Selectobjectsforgroup() tr.AddNewlyCreatedDBObject(grp, True) ' Open the model-space Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable) Dim ms As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord) ' Commit the transaction tr.Commit() End Using End Sub Private Function Selectobjectsforgroup() As ObjectId Dim mydwg As Document = DocumentManager.MdiActiveDocument Dim db As Database = mydwg.Database Dim myeditor As Editor = DocumentManager.MdiActiveDocument.Editor Dim myPPR As Point3d = myeditor.GetPoint("Select 1st Point: ").Value Dim myPPR1 As Point3d = myeditor.GetCorner("Select 2nd Point: ", myPPR).Value Dim mypsr As PromptSelectionResult = mydwg.Editor.SelectWindow( _ myPPR, myPPR1) If mypsr.Status = PromptStatus.OK Then Using myTrans As Transaction = mydwg.TransactionManager.StartTransaction For Each myObjectID As ObjectId In mypsr.Value.GetObjectIds Dim myEnt As Entity = myObjectID.GetObject(OpenMode.ForWrite) Next End Using End If End Function End Class Quote
