harshjhaveri Posted January 3, 2012 Posted January 3, 2012 Hi, I want to import data into AutoCAD which automatically draws the required diagram. Im working with .NET application that would send data in AutoCAD and then export the diagram back into my application. Can i send data thru a XML file or text file into AutoCAD or is there any other file format? Also help me with the syntax of the file ? This is the first time i am using AutoCAD. Thanks, Har**** Jhaveri Quote
BlackBox Posted January 3, 2012 Posted January 3, 2012 Welcome to CADTutor. I want to import data into AutoCAD which automatically draws the required diagram. If the diagram is going to be consistent (i.e., the same every time), then why not just insert a block? Simply draw the diagram (the block) as desired, then either Save As, or use the WBLOCK (write-block) command to create a new drawing. The resultant block can be stored on the network within the Support Files Search Paths (SFSP), or copied to each workstation with a batch file. If the diagram is not going to be consistent, and will vary depending on the ActiveDrawing's settings, and/or user input, then more information is needed. Hope this helps! Quote
