irneb Posted May 17, 2012 Posted May 17, 2012 I thought so as well at first. But doing a test resulted in an unfound file. I think the VLX compilation changes the call to open into a resource read operation. Anyhow, the VLX becomes quite large though, since the DXF is simply copied into it - no compression or such . Unfortunately there's not built-in binary read, so no way of simply including the much smaller DWG file, never mind something like a ZLib compressed resource. One could of course uuencode it, but then you'd need a uudecode.exe bundled with the VLX - not what the OP wanted from what I can understand. If you want it as small/fast as possible, then try one of those "convert to lisp" routines. Just remember that you mileage may vary, especially with stuff like dynamic blocks. Quote
anishtain4 Posted May 19, 2012 Author Posted May 19, 2012 (edited) Thank guys but actually I gave up on embedding block in the project in post #16, I was only looking for vla-insertblock, there is just one last point: I don't import a block from another drawing hence i guess copyblock would not help me, when I'm using (command "._insert" address *cancel*) the block will be loaded from the file once into the drawing, next time I can insert it with (vla-insertblock) from within the current document. is there anyway to just load the block with (vla-insertblock)? I tried to pass the nil as insert point and it loaded the block but the rest of commands will not be followed and routine stops right after that Edited May 19, 2012 by anishtain4 Quote
Lee Mac Posted May 27, 2012 Posted May 27, 2012 is there anyway to just load the block with (vla-insertblock)? I tried to pass the nil as insert point and it loaded the block but the rest of commands will not be followed and routine stops right after that You cannot omit the necessary parameters from the InsertBlock method, else this method will error (as you have experienced), instead, consider: (vla-delete (vla-insertblock <Container Block> (vlax-3D-point '(0.0 0.0)) <Block Name> 1.0 1.0 1.0 0.0)) Quote
