David Bethel Posted June 5, 2012 Posted June 5, 2012 Can Inventor import a DXF file the contains only AutCAD 3DFaces ( r12 format ) TIA -David Quote
JD Mather Posted June 5, 2012 Posted June 5, 2012 Yes, but 3D faces (solids) or 3D surfaces (surfaces)? Either way, yes. Quote
David Bethel Posted June 5, 2012 Author Posted June 5, 2012 Thanks! All 3DFACE Surfaces I take it LINEs and ARCs should not be a problem either? -David Quote
JD Mather Posted June 5, 2012 Posted June 5, 2012 Lines and arcs will be imported into a 3D sketch along with any surface or solid bodies (as long as the Import Options are set correctly). Quote
