dreams Posted July 26, 2012 Posted July 26, 2012 Hi all, I am new to this forum... Is it possible to create lisp for Revision cloud with tag? currently i am using Revision cloud in tool palettes with below mentioned command strings:- Single Text cloud - ^C^Ctcircle \\0.25 ^PR ^PV ^C^Crevcloud ^PO ^PL ^PN Window revision cloud - ^C^Crectangle \\Revcloud ^PO ^PL ^PN FYI... Revision cloud layer will be "0" & color in "Red" I have attached block for Revision number tag... Can anyone combine these commands in single lisp? It will be very helpful if it is possible... Rev# Block.dwg Quote
Lee Mac Posted July 26, 2012 Posted July 26, 2012 Try something simple like: (defun c:rv ( / *error* ar bn cm el fn rv ) (setq bn "Rev# Block") ;; Rev Cloud Attributed Block (defun *error* ( msg ) (if cm (setvar 'cmdecho cm)) (if ar (setvar 'attreq ar)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\nError: " msg)) ) (princ) ) (setq cm (getvar 'cmdecho) ar (getvar 'attreq) ) (cond ( (not (or (tblsearch "BLOCK" bn) (and (setq fn (findfile (strcat bn ".dwg"))) (progn (setvar 'cmdecho 0) (command "_.-insert" fn nil) (setvar 'cmdecho cm) (tblsearch "BLOCK" bn) ) ) ) ) (princ (strcat "\n" bn ".dwg not found.")) ) ( (zerop (logand 2 (cdr (assoc 70 (tblsearch "BLOCK" bn))))) (princ (strcat "\n" bn " not attributed.")) ) ( (setq *rev* (cond ( (= "" (setq rv (getstring t (strcat "\nSpecify Revision" (if *rev* (strcat " <" *rev* ">: ") ": "))))) *rev* ) ( rv ) ) ) (command "_.revcloud") (while (= 1 (logand 1 (getvar 'cmdactive))) (command "\\")) (setvar 'cmdecho 0) (setvar 'attreq 0) (setq el (entlast)) (princ "\nSpecify Point for Revision Block: ") (command "_.-insert" bn "_S" 1.0 "_R" 0.0 "\\") (if (not (eq el (setq el (entlast)))) (progn (setq el (entget (entnext el))) (if (entmod (subst (cons 1 *rev*) (assoc 1 el) el)) (entupd (cdr (assoc -1 el))) ) ) ) (setvar 'attreq ar) (setvar 'cmdecho cm) ) ) (princ) ) (princ) Quote
dreams Posted July 26, 2012 Author Posted July 26, 2012 (edited) Thanks Lee Mac...I heard about you lot that you are genius in Lisp programs... I tried this lisp....its good... but.... Is it possible to change lisp using above mentioned command strings? it will be great.. The Rev cloud will be come automatically to each word separate If we select single word or more words.... ^C^Ctcircle \\0.25 ^PR ^PV ^C^Crevcloud ^PO ^PL ^PN or if we make window select (Rectangle) 2 or more words... ^C^Crectangle \\Revcloud ^PO ^PL ^PN I have attached image file.. Edited July 26, 2012 by dreams Quote
SLW210 Posted July 26, 2012 Posted July 26, 2012 dreams, Please read the CODE POSTING GUIDELINES and edit your posts to place the macro in code tags. Quote
dreams Posted July 28, 2012 Author Posted July 28, 2012 Can someone help me regarding my above request? Quote
dreams Posted July 30, 2012 Author Posted July 30, 2012 Hi SLW210.. Thanks for your suggestion about CODE POSTING GUIDELINES..I have already edited my post...i have requested some changes needed in lisp...sorry for my English..I am not very well in English.. Quote
dreams Posted August 3, 2012 Author Posted August 3, 2012 Hi I am not very well in English (sorry)...I don't know about macros or visual lisp....can any one help me to change below macros for revision cloud with tag? I got this old macro in this cadtutor forum from another useful post..but i have edited some changes as per my requirements with my knowledge.. ^C^C(setq a(getvar "clayer"));-layer;M;DETAIL;;^C^Crectangle \\Revcloud ^PO ^PL ^PN;;\;-Insert;"Rev_Tri.dwg";\1;1;0;-layer;S;!a;; Its working fine but is it possible to scale up or down for "Rev_Tri.dwg" as per my required layout area like scale 1/2 or 1/4 or 1/8... FYI..currently Revision triangle "Rev_Tri.dwg" scale is 1/4.. triangle text height will be 4-1/2" inches... Can anyone help me? Rev_Tri.dwg Quote
