Hi,
I have several paralell working planes with 2d sketches. Sadly the parallel alignment is not correct, but I know the exact angle the working planes needs to be rotated. Is there a command to rotate a plane in 3d-space about a user-defined axis?
Best regards,
Ole
Your thread title (2d sketches) and your problem description (work planes) are two different things.
If you create the workplanes correctly then you can chang the angles after creation to any angles you want.
It sounds like you did not do this, creating them parallel offset rather than zero angle.
You will have to start over.
