mingyar Posted September 11, 2012 Posted September 11, 2012 Hello, I need a bit of advice, I want to simulate a car on top of a steel plate, I need to add the force normal to the plate face, I also know that I need to make the 4 tires areas that are in contact with the plate, to add the force on Inventor Stress simulation I need to just add the forces in those areas only, for doing that I need to split the face, but should I just do it on top of the plate or also on the bottom? What about if I do the same but instead of using a plate I use a tube? Do I need to split the top face or all the faces? Thanks Quote
JD Mather Posted September 11, 2012 Posted September 11, 2012 Split only the faces where the force is applied. Quote
