msanto64 Posted September 17, 2012 Posted September 17, 2012 I'm new to AutoCAD 3D and Rendering. In a model I'm currently working on, the colors I have in the 3D model become different colors when I create a rendering. For instance, in the model I'm working on, in the model, the object is blue, when I render it, it's grey. Can someone help me? Is there a setting I need to change? Thanks. Quote
JD Mather Posted September 17, 2012 Posted September 17, 2012 Can you attach a file here that exhibits this behavior? Have you fooled with Lighting? Quote
msanto64 Posted September 18, 2012 Author Posted September 18, 2012 I figured it out. In the Advanced Rendering Settings, under "Materials", "Apply Materials" was set to "On". Setting it to "Off" worked. Quote
