KarolR Posted October 9, 2012 Posted October 9, 2012 In Application Options, the sketch tab i enabled Autoprojec the part's origin on sketch create. I drew some lines and indeed a coincident constraint was added, but now it isn't added any more, just a usual snap. Why? Part1.ipt Quote
JD Mather Posted October 9, 2012 Posted October 9, 2012 Post screen shot of Application Options>Autoproject Post screen shot of Constraint Options Post screen shot of Constraint Persistence Did you restart Inventor and the behavior persists? Quote
JD Mather Posted October 9, 2012 Posted October 9, 2012 I drew some lines and indeed a coincident constraint was added, but now it isn't added any more, just a usual snap. Why? Uhmm did you delete some lines (I only see one line in the attached file). When you deleted those lines did you also delete the autoprojected origin? Quote
KarolR Posted October 10, 2012 Author Posted October 10, 2012 Where is the constraint Persistence option, apart from the button on the toolbar? Is the autoprojected origin possible to be deleted, and how do i know if it is? Yes, there is a possibility since i window selected lines, including the origin, and deleted. Quote
JD Mather Posted October 10, 2012 Posted October 10, 2012 You can delete any projected geometry, including the auto-projected geometry. Window select will delete everything in the window. Simply Project Geometry and select the Origin Center Point in the browser. Quote
