KarolR Posted October 17, 2012 Posted October 17, 2012 I hear i can use surfaces, but i don't see any command that enables me to make such. nor in the sketch, nor in the part environments, and also not on the Insert pull down menu/ There are the stitch, extend and trim surface commands, but how do i make a surface? Quote
ReMark Posted October 17, 2012 Posted October 17, 2012 Creating Simple Surfaces in AutoDesk Inventor http://mfgin3d.blogspot.com/2012/07/autodesk-inventor-creating-simple.html Quote
JD Mather Posted October 17, 2012 Posted October 17, 2012 There are a bunch of (older) surface tutorials here http://home.pct.edu/~jmather/content/DSG322/inventor_surface_tutorials.htm In Inventor you use the same tools to create surfaces that you use to create solids - just set the output to surfaces. Quote
