Mikey_Boson Posted November 26, 2012 Posted November 26, 2012 Not sure what I've done but I expect I've pressed something by accident and I'm now having issues. When moving the cursor over the drawing, it moves freely and the precision of the coordinates are still working to 4 decimal places. However, when I pick an object to move or copy and then try to move or copy it, the coordinate precision settings are changing to 0 decimal places and I'm unable to move things to exactly where I want - I can only move on a mm by mm basis. How do I return the precision settings of the coordinates back to 4 decimal places so I can move / copy objects without the current constraint I'm experiencing? Thanks!! Quote
MSasu Posted November 26, 2012 Posted November 26, 2012 Seems that you activated the snap mode accidentally - please press to disable it. Quote
Mikey_Boson Posted November 26, 2012 Author Posted November 26, 2012 Aha!! Thanks I knew it was going to be something simple. It's a function I personally don't use as I only do 2D drafting on a pretty basic level. Thanks again. Quote
MSasu Posted November 26, 2012 Posted November 26, 2012 Glad to hear that your issue is gone! You're entirely welcome! And, by the way, welcome to the Forum! Quote
Dadgad Posted November 26, 2012 Posted November 26, 2012 Welcome to the forum. Ah good, Mircea already got you squared away! You might still enjoy trying the suggestion below. Try setting your COORDS variable to 2, and see if you might like that setting, I know I do. These SYSVDLG values are from Autocad Vanilla, but I am guessing they will apply to LT also. Quote
